EE Auto Portforward
simple_faith
Lobby Username: simple_faith
EE Auto Portforward
Post by simple_faith »
Hi, releasing this program that was discovered by Tricky, repacked by me so you could get the pro version. This version will automatically open ports so you can host in EE/AoC, It automatically identifys your Router and Default Username/Password. I don't know if it's the program itself or my repack. But with the testers that tested it for me their router IP that the program identified did not match the right router ip. If that's the case with you open CMD (Windows 7: Go to start, in search box type cmd, then in cmd type ipconfig /all.) (Windows XP: Start, Run, CMD, ipconfig /all). Identify your default gateway IP, that's what it should say in the router ip in the program. Thanks to whoever tested it, you know who you are. (*Note: It is not my program. Credit goes to creator)
Here's the link.
http://www.megaupload.com/?d=N5B01COI
Here are some pics, so you can do it right, although it's pretty straightforward. (They are in order so you don't get confused)
*No this program will not work with everyone, but I gurantee it should work with most, Unless your router is from a 3rd world router or a bootleg.
Re: EE Auto Portforward
Post by [-Ts-] Tricky »
mine dont have one lol :( gateway ip on mine is nothing :(
simple_faith
Huh? You dont have a router or wut? Do you have a 3rd world one or a bootleg? Did you try to open cmd and type ipconfig /all? Hmm unless your behind 2 routers. And for me when i start the program everything is identified right but when people tested it they kept getting errors and i found out it was because default gateway didnt match router ip in the program. Anyways i can help you a little more later
NeveX
Lobby Username: NeveX
Post by NeveX »
Does it also work for aoc?
[-Ts-] Tricky wrote:Identify your default gateway IP, that's what it should say in the router ip in the program.
press the windows button + R to open "run", typ cmd and press enter.
As faith says, type ipconfig /all, you can also delete /all and just type ipconfig. This will also show your default gateway.
NeveX wrote:Does it also work for aoc?
EEC and AOC uses the same ports, so it should work. :- )
NeveX
Post by NeveX »
The link is dead.
NeveX wrote:The link is dead.
It's a megaupload link, it's up to faith to re-upload as I haven't downloaded it therefore I can't upload it :-P.
simple_faith
fawk i forgot if i still have the file
AEnima
Lobby Username: AEnema
Post by AEnima »
IDK why but for some odd reason I used to be able to host on EEC but not AoC when the real servers were up.
AEnima wrote:IDK why but for some odd reason I used to be able to host on EEC but not AoC when the real servers were up.
Are you sure AoC is allowed in the firewall? Best thing to do is turn off the firewall and see if it works.
If you always had both games open at the same time then that's why. If not, it was a software firewall issue (Windows Firewall or anything else you had installed)
Warmonger
Lobby Username: Warmonger
Post by Warmonger »
Most if not almost all routers support UPnP, so it would be easy to just open the required ports once you launch the lobby. Then close them once the lobby is closed (pretty much how utorrent etc works).
There is no place like 127.0.0.1 except for ::1 Image
calvhelp
Lobby Username: calv
Post by calvhelp »
is this link down?
Users browsing this forum: No registered users and 28 guests
