Did neoEE change ports?
- Xfire: p51p51
Both me and my cousin used to be able to host and now we can't. Does anyone have an idea why when we still have the port numbers in our router?
Re: Did neoEE change ports?
Are you using AoC? In EEC, something changed indeed, see neoee.net/faq
- Xfire: p51p51
In AoC, everything remained the same. UDP 33334 is most important port for game. If you use Direct connect, not NeoEE lobby, you also must forward UDP 33336 as well.
- Xfire: p51p51
Ok thanks.
I should have them already but I shall check to make sure they are still active.
Users browsing this forum: No registered users and 72 guests
