[DRAG]
Range - counters mirror
Hp -mirror / +gren
Att -mirror / +gren
Speed -all / =backline (super slow imps, explore)
[GREN]
Range - counters drag slightly
Hp - all
Att -cav / +gren
Speed - =frontline / +siege (max without civ bonus = most under rated)
[IMP]
Speed - counters cavs
Hp -drag / +gren
Att +gren
Armor +drag / ++gren
[SIEGE]
Att - early-mid pressure
Range - Light amount of siege
AoE - late game
Speed - super slow all (max = most under rated)
Rate of Fire - 4 or 5 resets, instead of 3 micro split
HP/Armor - Hero + Houses + Hospital, a few accompanied by 6 buildings > more than a tower for an early mine or forward base could ever do.
Eco Training - I highly recommend only aiming to create Siege to learn economy balance. Gold Bonus
I strongly recommend only creating a warrior hero to learn economy transition. Iron Bonus
**A Warrior Hero is [extremely cheap],
always keep that in mind!**
(before a 3rd mine, it's ideal to priority - way cheaper than it seems)
Besides imps, Speed is for strategy heroes.
Always train without CR(cost reduction) on Buildings
Helps a lot with memory and rotation
Forage Bonus only to understand TL.
Farm/Stone to understand DM.
Wood/Nothing to understand Pre2Mod
If the last three confuse you, it's not the idea until you base the first two. //
-NanoSL 10 Citizens, [Reaper]
-DarkTH 15 Citizens, [Gold]
(Eco/Military 'rush/boom' emphasis - Big/Small upgrades.
nano standard low; dark tournament high)
Tip: One attack upgrade only for both imps and siege.
+ Rate of Fire on Siege.
I'll update later on folding a line formation
And why it's the same + best thing to do not relying on a box formation or circle formation for random explore approach at no mountain disadvantage.
Tip: If you're facing high hp cavalry - use the box/rectangle formation; double/multi grouped a step or two in difference from each.
You will get get smoked if you don't in a DM/SH world even though you don't know you should know.
Tip: Open Square, finisher on low health army
ie: Retreat/Return a hospital
Tip: Tight Wedge - Soft-Counter Gren / Cav
Wide Wedge - Soft-Counter Cav / Gren
Reverse Tight Wedge - Halberdiers
Reverse Wide Wedge - Counter Hero / Tower
(l2 pre also)
Tip: Circle Formation - Soft-Counter Grenadier / Citizens / Farms
Tip: Circle + Tight Wedge = Get rid of Houses (morale)
Tip: Double open box formation: face the left side right, face the right side left - in that order.
(Imp breach reasons)
Tip: Double Reverse Tight Wedge - Pull back the top of the wedge on the second group \ Horizontal top speed control. (Grenadier Control)
Tip: Cross Wide Wedge - Rear Flank: Full & Half
(Dragoon Quad Critical)
- CycleOfLies, SilentButViolent, HybridEnergy. 2002-2004 / chilled with BONEZ and Wolfy.
Enjoy guys
ÐØGZ - Industrial Tactic
- Lobby Username: Lovesickdope
Last edited by Lovesickdope on Fri Mar 22, 2024 4:03 pm, edited 11 times in total.
Re: ÐØGZ - Industrial Tactic
M i r r o r C o u n t e r (M i c r o)
https://ibb.co/C6Hjg0c
https://ibb.co/GdFWkPZ
C o u n t e r
https://ibb.co/crKDhxZ
https://ibb.co/KLyzFQg
https://ibb.co/9YCWf3Y
3377 (Solo)
https://ibb.co/26h7xKh
https://ibb.co/sKzWQdt
P u b s t o m p / H e r o R u s h
https://ibb.co/NSkBwB9
https://ibb.co/wMvV7Q2
T o u r n a m e n t / B u l l y
https://ibb.co/7YP1wXR
https://ibb.co/Qn7CHj6
D e a t h m a t c h (Anti-Hero)
https://ibb.co/FgJrshP
https://ibb.co/ZLmK6t9
https://ibb.co/bXQwDXw
T w o - W a y (Team,Fog)
https://ibb.co/X3dhH5d
https://ibb.co/7pXRvsX
F o r w a r d (Medics)
https://ibb.co/4Tm6RzM
https://ibb.co/37VzTZb
D o u b l e R u s h (Wing)
https://ibb.co/h14zH0Y
https://ibb.co/NVwt41N
https://ibb.co/zsLtRrS
C r o s s F l a n k (Wing)
https://ibb.co/WgBvfD5
https://ibb.co/rs8cYzZ
B a c k d o o r D r a g o o n s
https://ibb.co/KKQrGST
https://ibb.co/NVtLHPW
R u s h B o o m (Tiny)
https://ibb.co/khCMZKK
https://ibb.co/ZBDXMKB
P r e s s u r e (1v1+)
https://ibb.co/pW7pCsP
https://ibb.co/Nt6xJy0
C l e a v e (1v1+)
https://ibb.co/vB3pmM3
https://ibb.co/g98hJf7
I d l e (1v1, Backline)
https://ibb.co/myPXGnC
https://ibb.co/CMn6wmb
I d l e V 2 (1v1, Frontline Return, Strategist)
https://ibb.co/r6GxgRZ
https://ibb.co/TbrXdR4
M u l t i - S o l o (1v2+)
https://ibb.co/ZfCR8q8
https://ibb.co/xq31Wms
O f f e n s i v e (Gigantic)
https://ibb.co/9yYwDHg
https://ibb.co/gJyqz32
https://ibb.co/DfpChY0
D e e p T o w e r s (2v2+)
https://ibb.co/yF4QDR2
https://ibb.co/Jr3ysLs
https://ibb.co/qdRBRmK
F a s t B o o m (2v2+)
https://ibb.co/T126KWz
https://ibb.co/RyzDtG2
https://ibb.co/S5hmy1t
M a i n S i x (2v2)
https://ibb.co/1smNwwZ
https://ibb.co/M7p4R2f
R e c o n / S i d e S w o r d (1v1/2v2)
https://ibb.co/T4sxxD9
https://ibb.co/yd9BNkz
R a i d i n g (Demolitions)
https://ibb.co/D78S9jC
https://ibb.co/F6NLrcD
https://ibb.co/L0WPj0Q
P e e l
https://ibb.co/R4N1s8M
https://ibb.co/SmCLJWF
R e v e r s a l (3v3+)
https://ibb.co/12qXvFX
https://ibb.co/0XQPkRJ
F F A
https://ibb.co/Gv7mcKY
https://ibb.co/WPJQzr2
O u t s i d e r (LOS)
https://ibb.co/9TyXgNm
https://ibb.co/ZdjX0rb
https://ibb.co/Cs37jFC
A g g r e s s i v e (SmallMap)
https://ibb.co/yF0XvBf
https://ibb.co/wJkBLxQ
https://ibb.co/Mn1Rvpg
S w o r d f i s h - 10/2 (2v2+)
https://ibb.co/Fw83SbS
https://ibb.co/jz25csZ
E x o t i c (OddTiming)
https://ibb.co/nzj4Xcn
https://ibb.co/1nHf0mt
L i g h t B o o m (Mix)
https://ibb.co/DgYNGqS
https://ibb.co/PW8KNZg
F l o o d (NoRepair)
https://ibb.co/xXhbWPK
https://ibb.co/ncdH1Yk
C o u n t e r G r e n
https://ibb.co/w615TSx
https://ibb.co/VJThmDt
C o u n t e r D r a g
https://ibb.co/9nC9xxm
https://ibb.co/JdGsvNW
C o u n t e r I m p
https://ibb.co/rd6hMN2
https://ibb.co/3YZbh1k
https://ibb.co/zxgYmx0
9 - 9 P e r i m e t e r (HeavyWing)
https://ibb.co/G7t104v
https://ibb.co/m0RBzXf
P u s h e r (Pocket/Inf)
https://ibb.co/WfSZgnF
https://ibb.co/xF8BgRz
E n e m y E c o (Flip)
https://ibb.co/Fm8Q0Xz
https://ibb.co/FqBYQr1
https://ibb.co/tDcLXtJ
B a l a n c e d
https://ibb.co/MkFhwYT
https://ibb.co/0jL25JT
B a l a n c e d B o o m
https://ibb.co/GpcKVj7
https://ibb.co/Xj51vcQ
P r i m e A s s i s t _ 5 5 (1v1/3v3)
https://ibb.co/fvJjXr6
https://ibb.co/X7JkzjS
S t r a t e g i s t S u s t a i n (Pocket)
https://ibb.co/L1R2H6n
https://ibb.co/cbQsZDL
S t r o n g h o l d _ 10/7 (3v3)
https://ibb.co/c1nqh3d
https://ibb.co/pZBnLt7
C o u n t e r B a l a n c e
https://ibb.co/Xp0YXdJ
https://ibb.co/jhRsFRM
https://ibb.co/gwNjHJS
S i d e W a r r i o r (3v3)
https://ibb.co/9nZF13S
https://ibb.co/Qv0GnWN
H a r d B a l a n c e
https://ibb.co/wR60QnM
https://ibb.co/fQz79p4i
https://ibb.co/WKWM6g6
C o n s e r v a t i v e C a m p s (MedMap)
https://ibb.co/tPvVSQ7
https://ibb.co/wJ5Q45J
K n i g h t (2v2/4v4)
https://ibb.co/v32Qtvj
https://ibb.co/3hFW9VQ
H e a v y B a l a n c e
https://ibb.co/XVzYkGy
https://ibb.co/pwNfYzj
H e a v y B o o m (Mix)
https://ibb.co/NyjbxPS
https://ibb.co/qBk8m0Q
S p l i t (LargeMap)
https://ibb.co/7KvPPtF
https://ibb.co/hM7kWpF
G r e n T o w e r s
https://ibb.co/tpj2665
https://ibb.co/CssLwXS
D r a g M o r a l e
https://ibb.co/WfYqkK3
https://ibb.co/CJDz2nD
H e a v y I m p
https://ibb.co/Zf5FPDj
https://ibb.co/82wLJCs
E l i t e H a n d
https://ibb.co/rfSbVQ5
https://ibb.co/8PSr8Z3
S h a r p s h o o t e r (Midline)
https://ibb.co/tcRMgGY
https://ibb.co/Sw77z1D
T a k e o v e r _ 13/9 (4v4)
https://ibb.co/zGPmDVN
https://ibb.co/wCZQbKG
A g g r o B o o m
https://ibb.co/5L25qgH
https://ibb.co/MgZNgjw
https://ibb.co/4RzF3Wq
M u l t i r u s h - S i e g e (4v4+)
https://ibb.co/vHB2Rqn
https://ibb.co/KFwv3gM
S u b m i s s i o n (Heavy Siege, 1v1/6v6+)
https://ibb.co/R6G2wH8
https://ibb.co/RPZYJ4r
https://ibb.co/jVrB5cB
A s s a u l t (5v5+)
https://ibb.co/k81RP12
https://ibb.co/GJsnhbC
https://ibb.co/C7PqqYD
D e e p s (5v5+/Siege Control)
https://ibb.co/Zc7Tp6S
https://ibb.co/sJY6C3n
O v e r l o a d (6v6+)
https://ibb.co/PmkrWLy
https://ibb.co/GHB6KKV
R u s h
https://ibb.co/2Zbn8Vf
https://ibb.co/Wnt6HYQ
https://ibb.co/26dH0Js
B i g B a s e (NoCav)
https://ibb.co/9ctTMQx
https://ibb.co/RSj279S
S p r e a d b a s e (NoSiege)
https://ibb.co/wdB9ScP
https://ibb.co/h761Pb4
S i e g e
https://ibb.co/g6D7z1B
https://ibb.co/0JD12Gt
https://ibb.co/5F38k5k
D e f e n s i v e
https://ibb.co/VvfC53T
https://ibb.co/vszC3Jc
4 - M i n e s (M a c r o)
https://ibb.co/F0RR30Z
https://ibb.co/tp0Kqq7
https://ibb.co/2h2MT54
C o u n t e r
3377 (Solo)
C l e a v e (1v1+)
M a i n S i x (2v2)
P e e l
F F A
C o u n t e r I m p
B a l a n c e d
G r e n T o w e r s
D r a g M o r a l e
H e a v y I m p
E l i t e H a n d
A g g r o B o o m
R u s h
S i e g e
D e f e n s i v e
