Freezing after some minutes
MrSir
Lobby Username: MrSir
Post by MrSir »
Hello together
I installed the Empire Earth game, patched it, set the allways start as administrator and testet the windows xp sp3 and windows 98 compatibility settings.
With Windwos 98 I can't start.
With the Windows XP and adminsitrator the game freezes aber one or two minutes, when I start a single player map.
I tried differenc card sizes, but getting the same result every time.
thank you in advance
MrSir
Re: Freezing after some minutes
Post by Locodoco »
MrSir wrote:Hello together
MrSir
try changing the resolution to anything that has 32x , I used to suffer from this but it worked after the change.
are you using windows 7 or higher? try compatibility for windows 7.
_[eC]_Arntzen_: :)
