Latency(Lag) Fix maybe???
Posted: Wed Mar 17, 2010 3:21 am
http://www.wowinterface.com/downloads/i ... cyFix.html
(Yes that is for WoW), but you can download it and install it without WoW it is a stand alone program that increases your TCP flow.
I don't think it would work because a lot of what he says in his FAQ deals with your relationship as PC->Server->PC, and this game doesn't have a server it is Direct Connect, but I remember having to open TCP and UDP ports to host, so maybe it would help. I'm not tech savvy enough to make a clear call on it.(Why I am posting it here)
. I even notice a difference on my FireFox.
If it would help with EE lag IDK. I would guess not, but I thought it was worth posting in chance it might if not this will speed up a lot of other stuff like streams, browsers etc, so I guess it is not a complete waste if it doesn't help you in EE.
As for the program it works GREAT to put this in EE terms say I have a 3 bar ping after I install this I have max ping always no matter what my fiance can download movies all she wants and I still have max ping barsDoes Leatrix Latency Fix work with any other games?
Leatrix Latency Fix modifies the way in which Windows handles acknowledgements to TCP segments. As such, it will affect any application that you have installed which uses the TCP protocol to transfer data. A lot of games use UDP so won't be affected but for the games that use TCP (such as World of Warcraft and Aion), you should see a significant reduction in latency.
