windows 7 prob
Posted: Sat Dec 19, 2009 3:20 pm
by semajoja
System.IO.IOException: Permission denied.
at Microsoft.VisualBasic.Interaction.Shell(String PathName, AppWinStyle Style, Boolean Wait, Int32 Timeout)
at LobbyUpdate.FormUpdate.dlf()
at LobbyUpdate.FormUpdate.wc_DownloadFileCompleted(Object sender, AsyncCompletedEventArgs e)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
LobbyUpdate
Assembly Version: 1.1.7.2
Win32 Version: 1.1.7.2
CodeBase: file:///C:/Users/semajoja/Downloads/LobbyUpdate(2).exe
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Windows.Forms
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
enabled.
For example:
<configuration>
</configuration>
this is the dl prob i'm getting.
sys
os-w7
procresser - intel 7i
vc- dual geo gtx 260x"black ed"
ram-12 gig
Re: windows 7 prob
Posted: Sun Dec 20, 2009 2:41 am
by Absolutely
Same thing happens to my Win7 notebook .
1,7Ghz dual-core
2G Ram
128Mb Intel GMA 945
Windows 7 Ultimate.
Re: windows 7 prob
Posted: Sun Dec 20, 2009 10:44 am
by Ghost
Looks like you're not giving it full permissions. The updater is trying to run the client on completion. This is the last thing the updater runs, so everything should be finished and you should be able to run the client (LobbyClient.exe). To try fixing the error, make sure UAC or Windows Firewall (Action Center) isn't blocking anything or try "Run as Administrator."
