Wrong Disk?
Riater
- Lobby Username: Riater
Wrong Disk?
I have all the patches loaded up but when I go to start the game it says I have the wrong disk inserted? does anyone have a fix for this or could walk me through the process on how to fix this?
Re: Wrong Disk?
you need to apply a 2.0 crack. (can be found in the patch area)
Riater
Re: Wrong Disk?
Already applied the 2.0 patch and thats when it started the wrong disk inserted BS lol
Riater
Re: Wrong Disk?
I was able to fix the issue. everything works except for that it seems really really glitchy is there a compatibility setting i need to adjust or something.
Re: Wrong Disk?
you need to apply a 2.0 crack (can be found in the patch area)Riater wrote:Already applied the 2.0 patch and thats when it started the wrong disk inserted BS lol
crack..
crack..
crack..
crackcrackcrackcrackcrack...
Riater
Re: Wrong Disk?
I got that now I ended up uninstalling everything and just following the step by step on this website lol. Game works now except for the fact that the video is all crazy flashy and glitchy. Idk what to do. I have literally tried everything I could think of. I have messed with the compatibility and that didn't fix it. The game seems like its going to run fine but once you get to the menu its just unplayable.
Running Windows vista 64 with ATI Radeon mobility HD 3870 X2. any help would be awesome please
Re: Wrong Disk?
try playing with the graphic settings ingame, if that doesn't work a downgrade of your graphic driver could be a solution.
