A Good Place To Start
Re: A Good Place To Start
Yes mine walling is allowed, you're allowed to place settlements around it to block off your citizen.
If mine walling wouldn't be allowed, the whole concept of walling (including walls) would be illigal in pre2nano/space.
You're just not allowed to 'box' your citizens in 1 square.
Minewalling is using buildings around one mine to completely block the access to that mine. This is not allowed. The rule you're suggesting is way too easy to abuse, which is exactly what happened.
Remember simple_faith and joey used to play p2s...
Using buildings to wall off a path, or even turn the map into two, is completely different, and is allowed.
i've played hundreds of p2s between 2010 and 2013 and mine walling was always allowed, just the 1 box thingy wasn't allowed.. We used to wall it so that there are 5 open squares around the mine. So I don't know when this 'no wall at all' rule was implemented, but back in the time p2s was played a lot (ofc less compared to old servers) it was still allowed.
What does "5 open squares around the mine" mean?
sorry i mean 3.
http://puu.sh/iCtyF/e684f2bb03.png
Grey: settlements
Black: tower
pink: iron mine
white: open spaces (3)
This has always been allowed when i was playing p2s games. Perhaps the rule changed between now and a year ago tho.
Grey: settlements
Black: tower
pink: iron mine
That hasn't been allowed since like 2011. Right before we made the no minewalling rule basically ever 4v4 game had 2 pockets going tower civ. While the wings was basically untouchable after like f11 20. This was incredibly boring, and we had to make the "no minewalling" rule.
What you're showing is exactly what would make a tower-player imba.
when 'we' so far only 'you' made that rule then. Since when 'I' used to play a lot of p2s, mine walling was only against the rules when you used 1 box/tile.
- AluminumJorne
- Lobby Username: AluminumJorne
Алюминиевый Кабель Прием на Переработку
Кабель из Алюминия Сдать Цена за 1 Кг
металлолом покупка на переработку цена за кг с вывозом в Ростове-на-Дону
В городе Ростов-на-Дону существует возможность сдать отходы алюминиевого кабеля и получить за них вознаграждение. Процедура приема алюминиевого кабеля на переработку является значимым шагом в направлении экологической ответственности и устойчивого потребления ресурсов. Лом алюминиевого кабеля имеет весьма востребованное применение в сфере переработки металлов и вторичного использования материалов. Организации, занимающиеся приемом алюминиевого кабеля, предлагают конкурентоспособные цены за каждый килограмм сданного материала. Это стимулирует население города активнее участвовать в процессе утилизации металлических отходов, таких как кабельный алюминий. Подобные усилия способствуют сокращению объема отходов, наполняющих свалки, и способствуют улучшению экологической ситуации в городе. Актуальность сдачи алюминиевого кабеля на лом в Ростове-на-Дону подчеркивает важность переработки и повторного использования материалов в целях содействия устойчивому развитию общества. Этот процесс способствует сохранению природных ресурсов, снижению выбросов вредных веществ и сокращению потребления первичных сырьевых ресурсов. Таким образом, инициативы по сдаче кабельного алюминия в Ростове-на-Дону не только принесут дополнительный доход, но и сыграют свою роль в поддержании здоровой экологической практики в городе. Переработка алюминиевого кабеля представляет собой важную часть процесса утилизации материалов и обеспечения устойчивости окружающей среды. Она включает в себя сбор, сортировку и переработку алюминиевого кабеля для повторного использования и уменьшения негативного воздействия на окружающую среду. Прием алюминиевого кабеля осуществляется специализированными предприятиями, которые занимаются его переработкой с целью восстановления ценных ресурсов и сокращения отходов. Шаги переработки алюминиевого кабеля включают в себя различные этапы. Сначала происходит сбор использованного кабеля, после чего он подвергается процессу сортировки, который позволяет отделить алюминиевый кабель от других материалов, таких как пластик или изоляция. Затем алюминиевый кабель проходит процесс переработки, включающий в себя очистку, расплавление и формовку, что позволяет получить вторичный алюминиевый материал. Прием кабельного алюминия имеет ряд преимуществ. Во-первых, это способствует экономии природных ресурсов, так как вторичный алюминий можно использовать для производства новых изделий, что уменьшает необходимость добычи первичных ресурсов. Кроме того, переработка алюминиевого кабеля снижает объем отходов и уменьшает воздействие на окружающую среду, так как это позволяет избежать складирования или сжигания отработанного кабеля. Таким образом, прием кабеля и его последующая переработка играют важную роль в обеспечении устойчивости окружающей среды и эффективного использования ресурсов. Этот процесс имеет значительные преимущества как для экологии, так и для экономики, поэтому внимание к утилизации алюминиевого кабеля является важным аспектом текущих экологических усилий
Ключевые слова: металлолом сдача с вывозом цена за кг Ростов-на-Дону, кабель алюминиевый в изоляции сдать в пункт приема лома цветных металлов цена, лом алюминия сдать, алюминий сдача на лом цена, металлолом прием цены за кг с вывозом Ростов-на-Дону
- scrap recycle_259.png (2.38 KiB) Viewed 1421 times
алюминий лом цены Ростов-на-Дону сдача алюминия на лом дорого Ростов-на-Дону
- AluminumJorne
Алюминиевый Кабель в Изоляции Сдать в Пункт Приема Цветных Металлов Цена за Кг
Прием Алюминиевого Кабеля на Металлолом
металлолом покупка на переработку цена за кг в РнД
В Ростове-на-Дону действует система приема алюминиевого кабеля, предоставляющая возможность сдать отходы алюминиевого кабеля в обмен на дополнительный заработок. Прием алюминиевого кабеля на лом является важным звеном в цепи переработки металлолома и способствует сокращению воздействия отходов на окружающую среду. Наличие системы приема алюминиевого кабеля способствует не только рациональному использованию ресурсов, но и стимулирует утилизацию материалов для последующего использования. Лом алюминиевого кабеля ценится на рынке металлолома в зависимости от цены за килограмм, которая определяется на основе текущих тарифов и рыночных условий. Жители Ростова-на-Дону могут обратиться в специализированные пункты приема металлолома для сдачи кабельного алюминия в обмен на дополнительный доход. Процесс сдачи кабельного алюминия на переработку обычно включает взвешивание материала и расчет вознаграждения в соответствии с текущими рыночными ценами. Сдать кабель из алюминия на лом в Ростове-на-Дону представляется удобной возможностью для граждан, желающих активно участвовать в процессе утилизации материалов и осуществлять ответственное отношение к окружающей среде. Помимо личной выгоды, участие в системе приема алюминиевого кабеля на переработку способствует не только минимизации воздействия отходов на окружающую среду, но и стимулирует развитие рынка металлолома и переработки материалов в регионе. Таким образом, сдать кабельный алюминий в Ростове-на-Дону не только обеспечивает дополнительный доход жителям города, но также способствует целенаправленной утилизации материалов и уменьшению воздействия отходов на экосистему. Участие в системе приема алюминиевого кабеля на переработку является важным шагом в сторону ответственного использования ресурсов и поддержания устойчивой среды для будущих поколений
Ключевые слова материала: прием металлолома на переработку высокая цена за 1 тонну с вывозом в Ростове-на-Дону, кабель из алюминия сдать в пункт приема цветных металлов с вывозом, сдать ломовой алюминий цена за кг, сдача алюминия на переработку с вывозом в РнД, цены на металлолом за тонну Ростов-на-Дону
- scrap recycle_50.png (6.09 KiB) Viewed 1317 times
- AluminumJorne
Кабель Алюминиевый в Изоляции Сдать в Пункт Приема Лома Цветных Металлов на Металлолом Ростов-на-Дону
Кабель Алюминиевый Сдать в Цветмет Дорого
сдача металлолома на переработку цены с вывозом в Ростове-на-Дону
Прием кабельного алюминия в Ростове-на-Дону играет важную роль в утилизации и вторичной переработке металлических материалов. Жители города могут сдать отходы алюминиевого кабеля за деньги, что способствует не только более эффективному использованию ресурсов, но также оказывает положительное воздействие на окружающую среду. Возможность сдать кабельный алюминий на переработку в Ростове-на-Дону дает горожанам возможность получить вознаграждение за утилизацию этого ценного материала, и тем самым способствует сокращению объема отходов и повторному использованию ценного сырья, что является важным аспектом для экологии и экономики региона. Процесс сдачи кабельного алюминия на лом в Ростове-на-Дону также содействует созданию дополнительных возможностей для граждан получить дополнительный доход. Цена за кг лома алюминиевого кабеля может варьироваться в зависимости от текучих рыночных условий, однако возможность получения компенсации за утилизацию материала делает этот процесс значимым как для граждан, так и для экономики региона. Таким образом, прием алюминиевого кабеля на лом в Ростове-на-Дону представляет собой не только экологически важную деятельность, но также способствует формированию устойчивой экономики и промышленности. Организации, занимающиеся приемом алюминиевого кабеля на переработку, играют важную роль в обеспечении устойчивого промышленного процесса и минимизации воздействия на окружающую среду. Возможность сдать кабельный алюминий в Ростове-на-Дону таким образом способствует не только получению дополнительных ресурсов, но и активно поддерживает цикл переработки материалов, что важно для улучшения экологической обстановки в регионе. Практика приема алюминиевого кабеля на лом является важной составляющей устойчивого развития и охраны окружающей среды в городе Ростове-на-Дону, что подчеркивает важность данной деятельности для обеспечения устойчивого развития региона
Ключевые теги раздела: металлолом прием на переработку цена за 1 кг с вывозом Ростов-на-Дону, алюминиевый кабель в изоляции прием цена за 1 кг, лом алюминия цена сдать, сдать алюминий на переработку цена цена за 1 кг в РнД, сдача металлолома с вывозом цены за тонну Ростов-на-Дону
- scrap recycle_265.png (4.46 KiB) Viewed 1257 times
