Can't log into EEC
Xfire: p51p51
Lobby Username: «•FRMB•»P-51
Can't log into EEC
Post by P-51 »
In the top left corner of my game it says that I am running v2.00.2539
When I try to create a user name and log in it says that I am running an outdated version and need to patch the game. I click "OK" and that exits the game and sends me to windows, where I get this message.
After clicking "Exit" and relaunching the game I get the same shit and I am stuck in some weird loop. I either need to install a patch manually or find a way to remove a false error message. Can someone help me with this?
Xfire: p51p51
Re: Can't log into EEC
Post by P-51 »
Bump Bump Bump Bump
Ehm open zzWONVersion (the cfg file inside EE folder)
Should say:
Version: 2.0.0.4
If not, maybe try manually changing to that. I got no clue if this will help or make it worse though.
Did you try full reinstall?
uninstall -> ccleaner -> remove bugged registry shit -> install EE 1.0 -> run patches -> go.
You should be alright if you just try to download the NeoEE patch again and install/repair. Manually changing zzWONVersion.cfg will allow you to login again, but your EE version won't match if you got an older version of the NeoEE patch.
Xfire: p51p51
Post by P-51 »
I tried uninstalling and got this error. I got it for both EEC and AoC. Does anyone know what this means?
i cant login either as it says my cd key is invalid... any ideas?
@P-51
No clue:S
@Slipknot
Does your version say v2.00.2949?
If so open WONlobby.cfg in EE folder and change CDKeyCheck to false.
CDKeyCheck: false // was false
I had this problem too, and this fixed it.
cheers
Xfire: p51p51
Post by P-51 »
Jodocus wrote:You should be alright if you just try to download the NeoEE patch again and install/repair. Manually changing zzWONVersion.cfg will allow you to login again, but your EE version won't match if you got an older version of the NeoEE patch.
Hey that worked. Thanks!
