Win 10 MP FPS problems
denis2904
Lobby Username: candenis2904
Post by denis2904 »
wenn i start a game with my 2 friends on any map bigger than medium my games goes down wo 8fps any any orders register after half a minute.
Bogdan_xD
Re: Win 10 MP FPS problems
Post by Bogdan_xD »
specs?..your computer config
denis2904
Post by denis2904 »
win 10 64bit
amd R9 290
i7-4820K quadcore 3.7 overclocked to 4.2
32gb ram
Are you running neoee patch?
Have you tried compatibility mode of win8 or earlier? This usually fixes most issues.
denis2904
Post by denis2904 »
what i tested is to turn off the hardware tnl but that just made it that i had grafic errors again but my fps were around 60
denis2904
Post by denis2904 »
im running the neoee patch my friends dont run into any fps problems and letting them host doesnt fix the problem for me after the fps get below 10 for a while everything becomes unresponsive and after some time it just desyncs because im so far behind them running the game in 98 maybe fixed the fps problem but i have to test it in mp since it makes the game crash alot until i get to a point were i can start a match
Bogdan_xD
Post by Bogdan_xD »
if you are saying you are getting only 60 fps, then it's normal.
To get higher, you need a higher refresh rate monitor.If you use more than 60hz monitor, the game should lock to that FPS.
