Hello,
I have a legal ee game,I updated it,and when I try the install the update lobby...nothing is working.
This is my problem hope You can help me
details
System.Net.Sockets.SocketException: An invalid argument was supplied 74.208.159.29:80
at System.Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult)
at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Int32 timeout, Exception& exception)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3082 (QFE.050727-3000)
CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
LobbyUpdate
Assembly Version: 1.1.7.2
Win32 Version: 1.1.7.2
CodeBase: file:///C:/Sierra/Empire%20Earth/LobbyUpdate.exe
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Windows.Forms
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
enabled.
For example:
<configuration>
</configuration>
Tried everything..desperate :(
Mr Janbo
- Lobby Username: Mr Janbo
- inola
Re: Tried everything..desperate :(
Ok, we're currently in the middle of transferring the save-ee.com domain name and apparently there's some quirks at the moment.
Try it again now.
If it still doesn't work then you can just download this ZIP file, which contains all current lobby files. Make sure you save and extract to a dedicated folder, do not run this out of your temp folder.
http://www.eeaoctraining.com/save-ee-lo ... .6.1.2.zip
Try it again now.
Mr Janbo
Thanks for the replies!
But I tried installing .net 3.5 and dowloaded "ghost" his files...again nothing worked.now when I try the startup the lobby client It now says "check your internet connection" and there is an internet connection..i set off mine firewall and virus scan and don`t have a router.
I loved this game playing online....mayve i give it a try to format my pc. My computer runs on xp 64 bit is that a problem?
Any way thanks for the help!
~Jan
~Jan
No, there's nothing wrong with your computer. I'll try to get things 100% working but until the domain registrar has everything in order, there's going to be errors.
Edit:
Ok as far as I know, everything is transferred. If you have problems still you need to clear your internet caches and temporary files.
Edit:
Mr Janbo
I cleared all mine temp. files and history files,with several programs,cleaned c:/ etc Is it possible that mine internet explorer have something to do with it...I run Firefox.
Greetz
~Jan
Greetz
~Jan
Yes, you should clear your IE temp stuff too, since that is what .NET uses.
