Hey all!
First off, just wanted to say GREAT JOB in creating this lobby!
so............
me and my friend are trying to play together via save-ee
I have everything successfully installed, took forever.
he was less fortunate however.
after installing the patches and .net framework he downloaded the lobby to install it
when he started installing it, he gets an error that says it needs to close down...send error report,etc.
what should he do????
thanks for the help!
Trouble installing save-ee lobby
Mookus
- Lobby Username: Mookus
Re: Trouble installing save-ee lobby
Try;
After you extract, the file "LobbyClient" is the one you'll use to launch the lobby. If you want a shortcut, thats the file you'll make the shortcut go to.Ghost wrote:download this ZIP file, which contains all current lobby files. Make sure you save and extract to a dedicated folder, do not run this out of your temp folder.
http://www.eeaoctraining.com/save-ee-lo ... .6.1.2.zip
