I need civ
Learn civs or post your own!
AraGoRN
I need civ
Post by AraGoRN »
Mod tl AOC plz
:D
Re: I need civ
hope these help ;)
-MoD TL Pock.civ
(64 Bytes) Downloaded 870 times
-MoD TL Wing.civ
(52 Bytes) Downloaded 872 times
AraGoRN
Re: I need civ
Post by AraGoRN »
WoW very fast
Thank you Slipknot ;)
Re: I need civ
These are eec civs? Or do you paly aoc slip? lol
Re: I need civ
Post by ben55 »
Those are vanilla civs almost all mod tls are on 1.1c, so ill send you the 3 I use
land.civ
(Same as Slip's civ but 5 more points are spent) Basically can do any wing unit combination with this civ INF/AT, M1/AT, M1/MORT;INF. Only real con is if you don't scout masses can overwhelm you, but if you scout and see them massing infantry make a few medics with the gold they mass M1 make some bazooka/AT, or if you have the wood make a tank fact and a couple Leopards.
(52 Bytes) Downloaded 795 times
air.civ
Start 3 to forage 2 to wood then after the 2 cits gather 15 wood make a tc on wood then play normal. You can take helicopter speed and Bomber speed out if you don't use those units often and put them on like Tank Attack or something.
(55 Bytes) Downloaded 779 times
1v1.civ
Helicopter BTD to stop forwards. You can trade the attack/hp on fighters and helicopter btd for Infantry Range/ Fighter BTD if you want I prefer this civ though. Controlling the air is very important from 10f11-20f11 and after 20f11 infantry range is kind of obsolete imo since arty become top dog. Though I do miss dearly range on snipers and mortars.
(47 Bytes) Downloaded 770 times
AraGoRN
Re: I need civ
Post by AraGoRN »
Mod SL now EEc :D
plz, thx
Re: I need civ
usually they pause for civ. i wud advise just making edits to civs.. use the normal tank and gren civs for TL. but u can add cit cost red to air civ by taking out AT ups and fighter hp
Return to “Civilizations”
