Hi,
I have a problem with hosting/port forwarding in EE.
I opened all required ports (33334 UDP/TCP, 33335 TCP, 33336 UDP/TCP).
My router: Mi Router 3C
Can you help me what I can do to fix this problem?
If you need more information (router settings or so) I will answer as soon as possible.
Thank you
_Johnsmith_
Port forwarding problem
_Johnsmith_
- Lobby Username: ALSAAD
- D55
- Lobby Username: D55
Re: Port forwarding problem
Are sure you chose the right IP in your port forward. You need to make sure its the computer you are using ee on. If there are other devices connected to the router you might have selected one of those ip.
In the lobby hit the options tab. Look where it says Local address. That is the ip for your ee computer.
you can just do the portforwarding with DMZ hosting , choose your IP and ready to go
_[eC]_Arntzen_:
_[eC]_Arntzen_:
_Johnsmith_
Hey all,
first of all, thanks for the help.
I checked the IP and its correct (local IP address).
Also I activated DMZ for test purposes. Even with DMZ activated I cannot host.
Pls, can you help me to fix this weird problem?
Greetings
_Johnsmith_
Greetings
_Johnsmith_
Try disabling the firewall (both on your computer and in the router if your router has one).
_Johnsmith_
Hey,
thank you for your answer.
My router (Mi Router 3C) has no firewall (at least I checked all settings/advanced settings and found no firewall settings etc).
I disabled the windows firewall ... but it didn't help at all.
Any ideas?
Thank you
_Johnsmith_
Any ideas?
Thank you
_Johnsmith_
Users browsing this forum: No registered users and 25 guests
