Indy DM is one of the most micro heavy battles in EE. Units to build are only bombards and dragoons and Napoleon.
And you gotta micro 2 (or did I do 3? I don't remember) balloons, to have them constantly moving in front of your army when in battle. You should try to never be moving into an area that you can't see.
So you gotta control group everything - I recommend 1 for goons, 2 for bombards, and 3 for goons+cannons to get the speed boost when microing, 4 and 5 for balloons. And a group for Napoleon to get him out of danger when needed.
For micro, indy DM is mostly about the bombards, and the goons are more like support. You wanna be constantly making the cannons all attack at once, using attack ground(constantly be attack grounding where you think their cannons - or goons, depending- are going to be when the balls hit the ground). Like 90% of the shots your cannons fire should be purely from an attack ground command. All 6 cannons at the same time, so if your shot lands, then you kill any goons or cannons that they hit. The moment you attack ground, then move your cannons back out of range, or to the side (to dodge their incoming cannon shots). Or sometimes move them forward, depending. Then a moment later, move back in and attack ground again. And your goons are basically support for the cannons and just dart in sometimes when needed or to finish off damaged goons, or dart in and kill their cannons quickly when the opportunity arises.
For instance, one of the indy dm techniques to attack ground is this: Say your armies are out of range, but moving towards each other. While your cannons are not in range yet, but close, be constantly be tapping the attack ground hotkey with your bombards selected, and then clicking a couple of inches in front of their army. So your mouse will basically be moving down the screen(as you tap t and click) as their army moves down. So that the moment your cannons get in range, they'll attack, and that attack will land where their army will be in a couple of seconds.
So these battles are all about the cannons trying to hit each other, basically. And trying to push and gain space through this method. It obviously gets more complex in practice, but this is the foundation.
And when you do actually want to move your goons and cannons together, you wanna aim the formation backwards, so hold down and pull the mouse in the direction of your army, so that the cannons lead the charge, or are in the middle of the goons. Otherwise the cannons will be too far back. This is a big part of the indy dm micro. You constantly want to be using the speed boost from grouping them with the goons when trying to gain space, so you do wanna constantly be using this, however once your cannons are close enough, switch to the attack ground technique with them.
If you can imagine doing this, pushing them all the way back to their city, where they'll be forced to not give you any more space, and then you can basically devastate them by attack grounding while they're in their own city, forcing them to come out, giving you a big advantage. So because of that, they will not just run away until they're in their own city - you'll both constantly be trying to push forward, but having to dodge each other's cannons.
And only 5 (or maybe 6, I don't remember) cannons per army! You just need enough that one hit from all of them kills a goon. If you have more than 6 cannons in your army, you don't get any improvement in damage(because you only need 6 to kill), and you have the risk of losing them all the moment the opponent manages to get 2 cannon hits on your cannons (if I remember correctly, 2 cannon hits kills a cannon. maybe it's 3).
So basically you want about 60 goons, and just 5-6 cannons, and use that army for battle. And replenish it as needed
I was to a top indy dm player(the other 2 best would be force_field and damn I can't remember the other guy's name, but he often would play with me and ff. We basically just would only lose to each other) and it's basically the best setting ever so it was fun to write this out.
Indy DM
Teopiltzen
- Lobby Username: Teopiltzen
Teopiltzen
Re: Indy DM
Oh and you don't need that many buildings. Build like 6-8 siege workshops, have them each build 5 bombards, and build like 8 stables, and have them each build like 15 goons.
Have them all spread around evenly, and don't have the units be sent anywhere when build. Just have them sit around their buildings. This makes your city have great defense without you having to do anything if someone tries to rush you or sneak attack your city.
If I remember correctly, you start by making napoleon at your capitol. I could be wrong about that.
So your 5 citizens at the start build 3 siege and 2 stables, and then 3 stables and 2 siege, and then a couple more of each, and then the temple of Zeus. I could be wrong about the build order, my memory is very hazy. But that's probably correct. Maybe you want to get a couple of citizens out before you get Nap.
Teopiltzen
Re: Indy DM
oh and control group 1 should be goons + Napoleon. And group 3 should be goons + bombards + napoleon
Sphinx
Re: Indy DM
Maaaan this is a fucking trip haha. Indy DM was hella fun, miss playing it with you and everyone back in the day.
What's funny about this set is it relies entirely on a glitch that allowed the bombards to move at the speed of the goons by holding down and specifying the direction that the units face when right clicking where to move. Somehow this weird glitch created an entire meta that felt very unique and distinct from the rest of EE, which I really enjoyed!
Teopiltzen
Re: Indy DM
Yo Sphinx I remember you! How crazy is this haha
Man I got really excited like a week ago when I found out about this and NoeEE, thinking there was still an EE community, but it seems like it's really just like 8 guys atm that are keeping it alive playing 4v4s together.
Do you ever play nowadays? If you wanna play some dm on NoeEE let me know! (I can't host games though atm)
Sphinx
Re: Indy DM
Man I wish, but I don't have a PC these days, only a MacBook haha, which means I'm shit out of luck. Haven't been on these servers in a looong time, but I heard that it's essentially dead. Good luck finding a game though. Maybe DM me your email or something so we can catch up.
Re: Indy DM
Solid guide Teopiltzen. I would avoid using the word "cannon" as it can easily be confused with Bronze Cannon. The only siege you ever make is Bombards.
Additions: Add 1-2 barracks for Partisan to shoot down the balloons (you especially do not want enemy to be able to have balloon camping over your army).
And of course when facing a really good opponent you should expect them to be using more than one group of army. You should also use more than one group. This makes Indy DM exponentially harder and incredibly intense. Using balloons and a few goons as scouts around your armies to get vision and to prevent getting flanked is important too.
Indy DM is a fantastic setting.
Teopiltzen
Re: Indy DM
ah yea bombard not cannon
and yea the "shoot down each other's balloons" is a hilarious side plot in indy dm battles
I actually am not a proponent of the multiple armies - I did lose to it the first time I encountered someone who was actually good at it (Captain Nemo took a game off of me, he was awesome). But yea once I got used to it I feel like you lose too much control when having to manage two armies, but I'm happy to be proved wrong if you wanna play some games together!
Sphinx - ah cool I'll dm you!
Users browsing this forum: No registered users and 70 guests
