Had a problem downloading the patch. The "Check for patch updates" and "Force Patch update" provided an error message which said "Unhandled exception has occurred...Index was outside the bounds of the array". I press continue and it searches for updates but the OK box doesnt allow me to update.
Can anyone assist
Thanks
Save EE Patcher 0.9.4
- PeLlE
- Xfire: thepelie
Re: Save EE Patcher 0.9.4
You can do the updates byself by browsing this sites portal. You will find every patch you need in order to get your game ready to play.
Usefull links:
http://save-ee.com/pages.php?p=26
http://save-ee.com/viewtopic.php?p=10292#p10292
Usefull links:
Please copy and paste the full error, including those in the details tab, to a post here on the forums and describe what (if anything) happens between the time you click the button and the time the error pops up.
Also, try using "Run as Administrator" on PatchUpdate.exe to see if that fixes the problem.
speedacb
thanks Ghost here is what the message says when I press "continue" after I get the error message "Unhandled exception has occurred..."
System.IndexOutOfRangeException: Index was outside the bounds of the array.
at PatchUpdate.Globals.UpdatePatchFiles()
at PatchUpdate.FormUpdate.CheckForUpdatesButton_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.4200 (NetFxQFE.050727-4200)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
PatchUpdate
Assembly Version: 0.9.4.0
Win32 Version: 0.9.4.0
CodeBase: file:///C:/Users/Carl/Documents/PatchUpdate.exe
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.4016 (NetFxQFE.050727-4000)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
Win32 Version: 2.0.50727.4016 (NetFxQFE.050727-4000)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
enabled.
For example:
<configuration>
</configuration>
mscorlib
PatchUpdate
System
System.Drawing
System.Xml
enabled.
For example:
<configuration>
</configuration>
I haven't been able to reproduce the error, nor pinpoint the location in my code that causes it. I'd really need more information than just the error.
Hit Force Patch Update. Does it finish downloading patchinfo.dat before you get the error? Does it download any other files? Perhaps paste here the text that's inside the Update window after the error (before you hit OK to close the window)...
I need to know everything that happens, even the tiny little details. If you can't do that, record a video of it or something?
