The installation of the first patch completed successfully.Empire Earth is not currently installed. You must have Empire Earth installed before you can install Empire Earth Difficulty Setting and Multiplayer Lobby Add-On.
Problem installing the second patch
vif
- Lobby Username: vif
When I try to install the second patch (German) I get this message from the installer:
Re: Problem installing the second patch
no idea if you resolved this or not
http://save-ee.com/pages.php?p=26
go there and do a manual install of the 2nd patch and see if that works
vif
I did not yet manage to resolve this.
I initially tried the manual install and it failed. Now I tried the PatchUpdate install and it failed as well.
@Sexa: The Patch Utility downloads the exact same file that you would get from the downloads page.
Anyway, I'm not totally sure what the 2.0 Sierra update looks for before it tries to run, so I can't offer you much help. I can tell you that it won't work on any "portable" versions of EE. The only thing I can really suggest is that you uninstall and then reinstall your game, then try repeating the process.
vif
Re-installing EE solved the problem.
