Cant login in lobby client
smarty
Hi guys, i download the update of lobby client
also the lobby client is included in that download
I copy the application
put them on my desktop and he give a fault
look image
look image
- fault.jpg (41.21 KiB) Viewed 10080 times
Re: Cant login in lobby client
well you just whispered me on the lobby so its working lol
smarty
You dont understand itSexacutioner wrote:well you just whispered me on the lobby so its working lol
I always have to take the download the update
and when i close the ee lobby
and i go to ee client -> he give that error.
Click details and copy/paste the whole error...
Also, have you tried basic troubleshooting?
smarty
System.IO.FileNotFoundException: Could not load file or assembly 'LobbyShared, Version=2.6.1.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
File name: 'LobbyShared, Version=2.6.1.0, Culture=neutral, PublicKeyToken=null'
at LobbyClient.FormLogin.FormLogin_Load(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
LobbyClient
Assembly Version: 2.6.1.5
Win32 Version: 2.6.1.5
CodeBase: file:///C:/Users/kriek/Desktop/LobbyClient.exe
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
enabled.
For example:
<configuration>
</configuration>
mscorlib
LobbyClient
System
System.Drawing
enabled.
For example:
<configuration>
</configuration>
- Spam4food
I think because you dont have NETFramework 3.5 lol there is a link on the front page to the update
It's pretty simple here.. you're missing LobbyShared.dll. Delete your lobby files, and redownload LobbyUpdate.exe. Make sure you save it somewhere and do not simply "open it" or save in the "Temp" folder because even though LobbyUpdate may download the file, it will get deleted automatically if you do either of those.
smarty
oke i will try it
so i download I delete all lobby stuff
I download it again
put lobby client & udpate in a map or something so its stays in a folder
I download it again
smarty
It dont work
smarty
hmm
were can i find temp folder
smarty
k i put it in TEMP
now just one thing dont work
if i copy it on my desktop
i cant open it when i click on the icon on my background
smarty
THX Ghost i fixed it
you gave me good tipe
i just make shortcut of the lobbyclient in folder "temp" put them in my taskbar and it works now
he said DO NOT save it in temp file, when you clear your temp folder with your net options you will lose your lobby, you should just save it to desktop as with anything you download
In order for the lobby to run you should have the following files in the same folder:
- LobbyClient.exe
LobbyUpdate.exe
PatchUpdate.exe
CustomPanels.dll
Language.dll
LobbyShared.dll
Network.dll
