EE-AOC Doesnt Works in WIN7
josephjoecastle
Lobby Username: josephjoecastle
Post by josephjoecastle »
Buenas tardes, estuve instalando EE-AOC pero no me funciona en mi compu,tengo un windows 7 una memoria -memory de 4 gb, una video de 256mb, procesador - Processator de 2.2 ghz, disco duro- Hard Disk 500gb.
EE works so good... both it found in the folder SIERRA.
EE funciona bastante bien... ambos se encuentran en la carpeta SIERRA.
When starts EE-AOC appears a black screen, before that loads the videos of entry of EE and when starts EE-AOC, means that not loading, it goes out and close auto,EE-AOC doesn't work in compatibility modes
cuando inicia EE-AOC aparece la pantalla negra antes de que cargue los videos de entrada de EE y MACLABS, o sea no cargan. se sale y se cierra automaticamente, ni en modo compatibilidad funciona EE-AOC
DAnke
DxDiag.txt
Config of my machine
(38.29 KiB) Downloaded 431 times
Trichome Indica
Re: EE-AOC Doesnt Works in WIN7
Post by Trichome Indica »
Try a basic re-install see if it helps. Mre info here,
by Omega » Wed Aug 12, 2009 5:26 pm
1) Uninstall the game by going to Start -> Control Panel -> Programs and Features (or Add/Remove Programs)
2) Go to where the game was installed to, and delete anything that is left there
3) Reinstall the game. Don't have the discs? See: viewtopic.php?f=10&t=734
4) Update your game to the latest version.
5) Try running your game.
6) If the Save-EE Lobby Client was installed to your Empire Earth or Empire Earth - The Art of Conquest folders, re-install it, but DO NOT UNDER ANY CIRCUMSTANCES install it to either of those folders again.
If your game works, stop now.
If your game does not work, repeat steps 1 and 2. Now do the following (If you are not comfortable editing your registry, or have no idea what you are doing, DO NOT ATTEMPT THE FOLLOWING STEPS. YOU CAN FUCK OVER YOUR COMPUTER--IF YOU DO, neither I, nor Save-EE or any of its staff is at all liable in any way, shape, or form. Instead, please contact a moderator or administrator in the lobby. Or try using the program you can get here (and if it still doesn't work than contact someone): http://www.ccleaner.com/):
7) run regedit.exe
8) find the relevant registry keys for Empire Earth, Empire Earth - The Art of Conquest, Mad Doc (make sure to only get ones for ee and aoc if you have other Mad Doc games), Stainless Steel Studios (same thing as goes for mad doc), SSSI (same thing as goes for mad doc again), and Sierra (same thing as goes for mad doc again). Delete the relevant keys.
9) Repeat steps 3 through 6.
If your game works, great.
If it still does not work, please contact a moderator or administrator in the lobby.
Private messageWebsiteMSNM/WLM
Users browsing this forum: No registered users and 67 guests
