EE Lobby Client Error
BigsY
Lobby Username: ][][-BigsY-][-MW-]
Post by BigsY »
So I reformatted my PC a couple of days ago and I wanted to reinstall the save-ee lobby today. So I downloaded the LobbyClient.exe file and ran it. It updated my EE and AoC with the appropriate patches then asked me for my login info, which I correctly supplied. It opened up the lobby interface and I got this...
http://img530.imageshack.us/img530/6718 ... lpplox.png
I had some trouble installing .net framework before I downloaded the client file. I installed .Net 4, but the Lobby wouldn't run with that, so I used .Net 2 and I got a bit further. I didn't uninstall .Net 4 before I installed .Net2 over it, but I wouldn't have thought that would cause a problem.
Re: EE Lobby Client Error
Ok so installing .NET v2.0 over top of v4.0 doesn't cause problems since they are in totally different folders on your system.
As for the error, I don't know how to fix it because I need you to click on the "Details" button and post everything in that box here. That way I can figure out what and where the problem is. Given the name of the error, it's probably some sloppy coding on my part and I can have it fixed in no time.
BigsY
Post by BigsY »
System.ArgumentException: Value does not fall within the expected range.
at System.Windows.Forms.UnsafeNativeMethods.IWebBrowser2.Navigate2(Object& URL, Object& flags, Object& targetFrameName, Object& postData, Object& headers)
at System.Windows.Forms.WebBrowser.PerformNavigate2(Object& URL, Object& flags, Object& targetFrameName, Object& postData, Object& headers)
at System.Windows.Forms.WebBrowser.PerformNavigateHelper(String urlString, Boolean newWindow, String targetFrameName, Byte[] postData, String headers)
at System.Windows.Forms.WebBrowser.Navigate(String urlString)
at LobbyClient.FormLobby.FormLobby_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
LobbyClient
Assembly Version: 2.6.4.0
Win32 Version: 2.6.4.0
CodeBase: file:///C:/Sierra/EE%20Lobby%20Client/LobbyClient.exe
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Accessibility
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
enabled.
For example:
<configuration>
</configuration>
Do you have Internet Explorer still installed and enabled? If you uninstall it, you won't be able to use the lobby. The lobby chat is a web browser window, and .NET web browsers implement IE.
BigsY
Post by BigsY »
Ok it is working now. As soon as you mentioned IE I had a feeling it would be related to the windows update for IE that needed my PC to be restarted, which I hadn't done yet.
Thanks :D
Mencontar2K7
Lobby Username: Mencontar2K7
Post by Mencontar2K7 »
i seem to be having a similar issue :( although i still have IE and have had no recetn NET. framework update.
It worked at one moment then my computer overheated and rebooting auto, upon reloading i tried to load the client and was presented with the same framework popup, details listed below:-
System.Configuration.ConfigurationErrorsException: Configuration system failed to initialize ---> System.Configuration.ConfigurationErrorsException: Root element is missing. (C:\Documents and Settings\SPEAKMAN\Local Settings\Application Data\Save-EE\LobbyClient.exe_Url_cr44aww2akeihaf15zdrxwlzwwnyhfnz\2.6.5.2\user.config) ---> System.Xml.XmlException: Root element is missing.
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.ThrowWithoutLineInfo(String res)
at System.Xml.XmlTextReaderImpl.ParseDocumentContent()
at System.Xml.XmlTextReaderImpl.Read()
at System.Xml.XmlTextReader.Read()
at System.Configuration.XmlUtil..ctor(Stream stream, String name, Boolean readToFirstElement, ConfigurationSchemaErrors schemaErrors)
at System.Configuration.BaseConfigurationRecord.InitConfigFromFile()
--- End of inner exception stack trace ---
at System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors(Boolean ignoreLocal)
at System.Configuration.BaseConfigurationRecord.ThrowIfParseErrors(ConfigurationSchemaErrors schemaErrors)
at System.Configuration.BaseConfigurationRecord.ThrowIfInitErrors()
at System.Configuration.ClientConfigurationSystem.OnConfigRemoved(Object sender, InternalConfigEventArgs e)
at System.Configuration.Internal.InternalConfigRoot.OnConfigRemoved(InternalConfigEventArgs e)
at System.Configuration.Internal.InternalConfigRoot.RemoveConfigImpl(String configPath, BaseConfigurationRecord configRecord)
at System.Configuration.BaseConfigurationRecord.GetSectionRecursive(String configKey, Boolean getLkg, Boolean checkPermission, Boolean getRuntimeObject, Boolean requestIsHere, Object& result, Object& resultRuntimeObject)
at System.Configuration.BaseConfigurationRecord.GetSection(String configKey, Boolean getLkg, Boolean checkPermission)
at System.Configuration.BaseConfigurationRecord.GetSection(String configKey)
at System.Configuration.ClientConfigurationSystem.System.Configuration.Internal.IInternalConfigSystem.GetSection(String sectionName)
at System.Configuration.ConfigurationManager.GetSection(String sectionName)
at System.Configuration.ClientSettingsStore.ReadSettings(String sectionName, Boolean isUserScoped)
at System.Configuration.LocalFileSettingsProvider.GetPropertyValues(SettingsContext context, SettingsPropertyCollection properties)
at System.Configuration.SettingsBase.GetPropertiesFromProvider(SettingsProvider provider)
at System.Configuration.SettingsBase.GetPropertyValueByName(String propertyName)
at System.Configuration.SettingsBase.get_Item(String propertyName)
at System.Configuration.ApplicationSettingsBase.GetPropertyValue(String propertyName)
at System.Configuration.ApplicationSettingsBase.get_Item(String propertyName)
at LobbyClient.My.MySettings.get_UpgradeSettings()
at LobbyClient.FormLogin.LoadPrefs()
at LobbyClient.FormLogin.FormLogin_Load(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
mscorlib
Win32 Version: 2.0.50727.3620 (GDR.050727-3600)
CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
LobbyClient
Assembly Version: 2.6.5.2
Win32 Version: 2.6.5.2
CodeBase: file:///C:/Documents%20and%20Settings/SPEAKMAN/Desktop/LobbyClient.exe
Win32 Version: 8.0.50727.3053 (netfxsp.050727-3000)
System
Win32 Version: 2.0.50727.3614 (GDR.050727-3600)
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
System.Drawing
System.Xml
Win32 Version: 2.0.50727.3082 (QFE.050727-3000)
enabled.
For example:
<configuration>
</configuration>
help would really be apreciated people ^_^
Navigate to that file and delete it. It seems that it has been corrupted.
Mencontar2K7
thank you very much, i didnt even think to look in its save directory :(
worked first time after i delleted though ^_^
