Hi, I have a 3800HGV-B 2WIRE modem used for att uverse. I know the tcp and udp ports to forward for empire earth on my router. However, my game isn't show in the lobby. Does the save ee lobby support my 3800HGV-B 2wire modem? Am I doing something wrong? Btw I followed the directions from port forward.com, heres the link below:
http://portforward.com/english/routers/ ... _Earth.htm
Another can't host question
cuil
- Lobby Username: Cuil
cuil
Re: Another can't host question
I would like to add that I used port checker from portforward.com to check if my ports are open and all of them 33335-33336 tcp to 33334 udp are open
To get your game to show up in the lobby, you need to do the following:
On both your game's "Option" tab in Other Multiplayer, and the "Option" tab in the lobby, you must select your correct IPv4 address (example: 192.168.1.104).
Do this in the lobby by simply selecting the correct address from the list in the Network Details box of the Options tab, and do it in the game by clicking on the Options tab in Other Multiplayer, clicking the "Choose network adapter..." button, and selecting whatever has the correct address associated with it.
As for the ports you need to forward, those are so that people can actually join and play in your hosted game. If you followed the directions on Port Forward, you should be set, but I'll just re-list the specific ports anyway:
33334 and 33336 both TCP and UDP
33335 TCP
OR, as I usually tell people, just do the range of 33334-33335 TCP and UDP, because that's nice and simple
33335 TCP
cuil
thanks it worked!
Users browsing this forum: No registered users and 68 guests
