Okay i just learnt this one..
And i found it awesome..
Okay you have 1 cit and 50 food you want to Hunt the Hippo
Lure him to the cap.
and kill kill kill
Then gather..
whilst doing this build a cit from cap all together you want 3 citz on 1 or 2 hippos.
then when you have enough food you want 4 on wood.
then 2 on gold
then back to the wood from cap.
When your hippos are depleated.
get the 3 cits from hippo's on to a forage patch and 2 from the wood also.
Now you should have 6 on the forage..
When you have enough wood build a stable.
Then from cap get your citz on to gold so you need another 4 to make it 6.
When you have enough wood build a settlement on your gold get more citz from your cap to your, wood.
when you have enough wood build archer range.
You want persian cav and Archery cav.
when youve done this get another gold patch and build a farm and populate your settlement using wood citz.. go on from here build build build..
works for me.
best of luck please REPLY..
Tricruiter sparky - btw i did all this from menory ^
CIV
You want cost reduction build time decrease in your buildings.
Wood and hunting and foraging.
Cit speed.
Cit cost reduction and build time decreased and choose what ever you like in the cav range.
MID SL
- LacRimoSa
- Lobby Username: [-Ts-] LacRimoSa
Re: MID SL
built time is pretty useless.. since it's no sh/rush set.
Re: MID SL
It is a rush set.. Instead of that, without a rush will give the enemy an oppertunity to outboom you.LacRimoSa wrote:built time is pretty useless.. since it's no sh/rush set.
- LacRimoSa
Re: MID SL
I sometimes even play sh games without built time cuz it's just worth for fast towers. Most of the time, there r better things you can spent ur points at.
Mid sl is anyway just about cit rush.
However, I haven't played that many mid sl games. I might be wrong.. idk.
- Absolutely
- Lobby Username: GoG_AbsoLuteLy
Re: MID SL
imo sword rush is a way better idea than cav archers/persians due to the lower cost and cuz your enemy won't have any towers to prevent swords from eco raping.
Re: MID SL
I think building time decrease is not important for only your towers, but also for your barracks etc, because you want your rush as fast as possible, the building can be completed with a 30% time reduction.LacRimoSa wrote:I sometimes even play sh games without built time cuz it's just worth for fast towers. Most of the time, there r better things you can spent ur points at.
You are absolutely right if you meant Mid sl for gays and retards. But definately not for good games.LacRimoSa wrote:Mid sl is anyway just about cit rush.
Users browsing this forum: No registered users and 32 guests
