EE-AOC LAN NOT WORKING
petar74
Lobby Username: petar74
Post by petar74 »
Hi guys and thanks for you help.
I'm having a problem with ee-aoc lan. You see lan on standard ee is working fine and also multiplayer via internet on neo-ee server is working.
The thing is I can't seem to see lan games on ee-aoc, but I can play online via neo-ee server using ee-aoc. Please help!
Keep in mind that I was testing Empire Earth using a desktop computer and a laptop. The laptop has several network adapters and I'm suspecting that that might be the problem. One more thing. The only update I've installed was neo-ee. Are there any other updates that I should've installed and what version of the game I need to have?
Empire Earth = v2.00.3750
Empire Earth - The Art of Conquest = v1.00.7590
Thank you!
Re: EE-AOC LAN NOT WORKING
Honestly not that experienced with lan, been way too long since I tried. Find it very odd that it works on normal ee and not aoc. Try look to see if ee and aoc have same settings in the other multiplayer tab.
Open EE->Multiplayer->Other Multiplayer->Options->Chose Network Adapter
Open AOC->Multiplayer->Other Multiplayer->Options->Chose Network Adapter
Compare these two.
Also I remember from back in the day when I did lan parties, we always had to turn off anti-virus and windows firewall, maybe that is a solution to you too.
Anyway, if LAN doesn't work, you could just play on NeoEE right?
Edit: Your version is correct. Did you check that those versions are the same on both computers though?
petar74
Post by petar74 »
Thank you for replying. One of the first things I checked were the settings in the other multiplayer tab and they were the same except on the laptop it was selected the name of my network card and not "default adapter card". I changed does settings and they did not work either. Yeah I can play NeoEE on AOC so this really isn't that big of a problem and the version were the same on both computers. If you find the same problem on your end please reply and also if you find a solution. Either way thank you.
petar74
Post by petar74 »
I have one more problem. Can you explain to me what are the requirements for hosting a game on NeoEE because I tried several time and it's says that the NeoEE server can't verify my connection and when my friend tries to play with me it says that he can't ping me and we can't launch the game. Do I need to port forward or what? Please help.
Post by Bogdan_xD »
Port Fowarding does help, although there's numerous players that are playing without it.
petar74 wrote:I have one more problem. Can you explain to me what are the requirements for hosting a game on NeoEE because I tried several time and it's says that the NeoEE server can't verify my connection and when my friend tries to play with me it says that he can't ping me and we can't launch the game. Do I need to port forward or what? Please help.
Most can host on NeoEE without port forwarding, but to be 100% sure you can always host I always recommend port forwarding since works all the time. *ONLY* the host needs to do this though.
EE and AOC both needs 33334-33336 UDP/TCP.
I can help you if you need to set it up or you could just follow this:
https://portforward.com/empire-earth/
Phony6944
Post by Phony6944 »
Hey everyone,
i would like to necromance this thread since the lan problem seems still existing. I'm currently sitting on 1 of 5lan partys a year and discovered Neo-EE.
First of all, thanks!
The normal EE seems working fine in lan, however, AOC is not working at all. Since I'm able to get it to work on normal EE i think I'm skilled enough to configute my lanadapters and the firewall ;)
Is there any plans on getting this fixed? Or does anyone have an idea what exactly is not working?
In AOC I'm unable to see my own hosted game in the networklist, but this should be working.
Best
Phony
rowsdower
Lobby Username: rowsdower
Post by rowsdower »
Hey I don't think many people go on these forums anymore. You're saying you can't play local multiplayer between computers on your network? I am interested in this as well.
Phony6944
Post by Phony6944 »
Yeah NeoEE-AOC is not working.
NeoEE works like a charm.
sk0rpi0n
Lobby Username: sk0rpi0n
Post by sk0rpi0n »
August 2024, same situation for me.
I'm an informatic technician, already tried everything and yes, I'm skilled enough with networking and port forwarding; 3 PCs with Windows 10 and NeoEE vanilla is working in network like a charm, BUT NOT NeoEE AoC with the same settings!
I'm in vacation with my sons (6 and 9 years old) and we have 3 notebooks on which sometimes we like to play EE and many more games; we have no internet/router, I simply brought a network LAN switch on vacation ant the 3 notebook have static IP address, same subnet masks and as gateway and DNS the IP address of the master PC (the one hosting games).
With all the other games all is fine (Starcraft, Red Alert 2, Lord Of The Rings, NeoEE, etc.),I can host games on my notebook and the other PCs can clearly see my LAN game on the network.
NeoEE AoC is a different story: no way to make it work!
What I tried:
- Enable the 33334, 33335 and 33336 TCP and UDP connection in Windows Firewall;
- Then completely dissable Windows Firewall on alls PCs;
- Tried both LAN and Direct Connect connection types, specifying the host IP address;
- Tried to select the correct network adapteri in NeoEE AoC;
- Disabled all the other network adapters including WiFi to be sure a single adapter remains;
- Many other attempts thying playing with IP address, gateways, DNS, etc. on the PCs.
Please note that i can correctly ping fron the clients to the IP address of the host and I get response, so I'm sure of the network settings.
When hosting a game I get always the error:
"NeoEE was not able to verify that your machine can accept connections from other players. Other players may have difficult joining" etc.etc.
especially when using Direct Connect, but after some attempts it goes away; when hosting via LAN i don't have this error, but except this I have on all the other clients the same error trying to connect in direct IP with the host:
"Code: WS_ServerReq_NoServersSpecified"
No network games will be shown when in the client I try with "LAN", even refreshing.
Note that at home we had no problem running network games, but I remember I had to enable UPnP on my router in addition to all the other settings.
I think NeoEE AoC has a completely different way to communicate via LAN with the other PCs comparing to NeoEE vanilla, because the error is always the same.
I read in some forums that this could have something to do with the "WONLobby.cfg" file, but after many attemps trying to modify the file I didn't make it anyway.
Any help?
Is there a way to make NeoEE AoC communicate via LAN as NeoEE vanilla?
What's the difference between the two?
Thank you, any help would be appreciated.
sk0rpi0n
Users browsing this forum: Bing [Bot] and 62 guests
