I have the original EE-gold edition with both updates installed.
ee_1000-1040_en.exe EE upgrade
si_empireearth_update_en_1004_2000.exe Adds multi-player lobby.
The GOG version installs both at once. Here's are the version numbers. I need to know if the GOG version is up to date.
GOG
Basic v1.00.3946
AOC v1.00.2020
Bought version, two cd's
Basic v2.00.3466
AOC v1.00.2657
Standard edition vs GOG version
breascil_imreoir
- Lobby Username: Tiarna Limistear
Last edited by breascil_imreoir on Tue Jan 17, 2012 2:00 am, edited 1 time in total.
breascil_imreoir
Stanard edition vs GOG version
Additional notes:
Standard Gold Edition-CD with updates:
AOC works fine. EE-Basic has graphical glitches and is unplayable.
GOG edition works with either.
Re: Stanard edition vs GOG version
The version numbers that you get from the CD installed version are the ones that are generally accepted as correct.
Having files in the ../Data/db, ../Data/Models, and ../Data/textures folders will also effect the version number (except ../Data/Models/amb_rock.cem, you're supposed to have that for v2.0 I think, maybe even 1.0.4.0 but I don't remember)
gog versions other people had problems before patching and everything if i was you i would download our version and will work fine anyway
breascil_imreoir
GOG and CD version
Basic v2.00.3466
AOC v1.00.2657
I removed the db and textures folder. I rechecked the version numbers, they match.
>gog versions other people had problems before patching and everything if i was you i would download our version and will work fine anyway.
I downloaded the patches that I found. I'll try to install them onto GOG version.
Basic v2.00.3466
AOC v1.00.2657
