Hello,
I have a problem in the initial setup. I get the following message:
"empire earth the file data.ssa does not match the file in the setup's .cab file"
What should i do?
abcd
- Lobby Username: abcd
Re: data.ssa does not match the file in the setup's .cab fil
If you're installing from a disc then it might be scratched and all you can do is try again. If it repeats then you can't do anything really.
If you downloaded it then you should try re-downloading or downloading from a different location. Sometimes when you download large files there can be small errors in them that throw off things like this.
abcd
Thanks
The initial Cd, from where I made the setup was corrupted. I changed it with my back up and now it is OK. Thank you.
