Changing Epochs
dvdbvt
- Lobby Username: dvdbvt
Changing Epochs
I've started making my own custom scenario. I'm an epoch 12 civilisation taking on a computer controlled epoch civilisation. My question how do I make the Black Robe soldiers and the Black Robe Officer available an Epoch early. How do make German Infantry still available in epoch 13 for my computer opponent.
- Xfire: p51p51
shieldwolf23
Re: Changing Epochs
is this while you are playing a skirmish/ random map? if yes, like pz said, you can't.
but if you are using the scen editor, you can. just go to the Effects section, select Modify-Tech-Tree for Player 2 (computer), ADD Black Robe to its technologies. Be sure to have the AI in active, cheat, ignore mode. This way, the AI will be pretty much aggressive.
To be extra sure, you could also set the AI favorites - Land Unit to Black Robe.
Re: Changing Epochs
Yea, or use the trigger system to define AI's.shieldwolf23 wrote:is this while you are playing a skirmish/ random map? if yes, like pz said, you can't.
Users browsing this forum: Bing [Bot] and 60 guests
