Can't play multiplayer
RogueStove
Lobby Username: RogueStove
Post by RogueStove »
I keep getting the error no CD-Key when trying direct access with my two friends. :(
Re: Can't play multiplayer
Post by Bogdan_xD »
why not use the Lobby then?
or can't you connect to that either?
Try to run the installer and hit "Repair CDKey". Good luck, Jodocus.
RogueStove
LAN works but im trying to play with another friend from far away. Every time i try to install or repair CD keys it tells me 'CD KEYs could not be installed due to command line failure.'
RogueStove
Ok I've figured it out. Thanks all who tried to help.
supercooler88
Lobby Username: supercooler88
Post by supercooler88 »
HOw exactly did you figure this out. Can you please explain?
Thanks,
Post by Bogdan_xD »
Install the NeoEE patch with the antivirus dissabled . Antivirus is stopping the installment of the CD-KEYS.If you have it dissabled, when you install the patch, it should say at the end "CD-KEYS succsesfully installed" , if it doesn't it's because of your antivirus stoping it.
Just dissable the antivirus, install the patch and make sure you get that message, then you can re-enable your antivirus.
Users browsing this forum: No registered users and 77 guests
