How to host using omegas latest patch eec/aoc
herik
Momma's boy
Lobby Username: herik
Post by herik »
Dial up/usb wireless-
These two are the easiest, but the slowest :P-
1. Make sure your connected!
2.Go to> eec/aoc>multiplayer>othermultiplayer>options>press "change" next to LAN
Broadcast Port>make numbers around 33336, so do 33335 or 33337.
3. Put eec/aoc as exceptions on firewall
4.Time to host and this is how...load up eec/aoc>multiplayer>other multiplayer >Direct Connect>
Host Game>Play with your friends
Modem-These are a little harder but worth it in the end-
2.Go to> eec/aoc>multiplayer>other multiplayer>options>press "change" next to LAN
Broadcast Port>make numbers around 33335, 33334-33336.
4.Go to website portforward.com>press Routers(Navigation menu)>Choose your Router>Choose
the type>Scroll down to the letter "E" and find Empire Earth OR Empire Earth The Art of Conquest
(doesn't matter which one, because both games use the same ports. open port for EE will let you host in aoc too, and vice versa)>Make sure to follow ALL the
instructions, don't bypass the static ip, THATS VERY IMPORTANT. Once this is all done do the
following:
If anyone has an problems with this, please comment, as I'm sure i've missed a few steps.
herik
Momma's boy
Re: How to host using omegas latest patch eec/aoc
Post by herik »
If any1 has any problems PLEASE GIVE FEED BACK! just write what step didn't work for you.
But if you're ignoring half of the instructions and only following 99% of them don't complain it doesn't work. Follow them all, and then say you have a problem with it. cheers.
herik
Momma's boy
Post by herik »
[13:43:26] Machiavelli: Yeah.... I live in an apartment... and Idk what the router is...
[13:45:07] «{Co}» Sexacutioner: go to start
[13:45:17] «{Co}» Sexacutioner: in the run box type cmd then hit enter
[13:45:29] «{Co}» Sexacutioner: when thats open
[13:45:33] «{Co}» Sexacutioner: type ipconfig
[13:45:46] «{Co}» Sexacutioner: look for your default gateway #
[13:46:01] «{Co}» Sexacutioner: type that into your web bar and hit enter
[13:46:23] «{Co}» Sexacutioner: or are you on a community router lol
[13:46:37] Machiavelli: community router
[13:47:11] «{Co}» Sexacutioner: you will need to talk to the owner of the router to see if he will set it up for you most likely then cause you need the pass n poopie
i accidently typed in wrong thing on lobby which i changed later, edit by sex
herik wrote:Dial up/usb wireless-
following:
33335 - 33337 ???????? Where do we need port 33337 for????? :) (33334-33336)
herik
Momma's boy
Post by herik »
noob, it can be any number arround 33336
Users browsing this forum: No registered users and 66 guests
