Ee maxing my cpu
Nanofurry
Lobby Username: Nanofurry
Ee maxing my cpu
Post by Nanofurry »
This is pritty much it... EE only useing one cpu core and maxing out and crashing my pc i have a
Is there a way to make it use all my cores? Is there a patch for that?
Intel 2500k
Ssd
7870oc
16gb ram
24inch led
Fast internet
Re: Ee maxing my cpu
Post by [-Ts-] Tricky »
i would say re download ee again i couldnt see ee running on a single core being the problem
viewtopic.php?f=10&t=4889 there is a ee/aoc download link i also messaged omega maybe he knows something or someone else does
Nanofurry
Post by Nanofurry »
[-Ts-] Tricky wrote:i would say re download ee again i couldnt see ee running on a single core being the problem
It not that the game was only made to work on one ore or old DUO cores... i know 2 other people that have the same core as me and have the same problem. even my boy friend's old Q9400 use's only one core and maxes out.. but not all the time tho
if you dl from the link tricky gave you then you probably installed it wrong, ive had to help 5 others with same problem with that link
it says " do not use lobby patches "
viewtopic.php?f=10&t=4091
this is for a dif dl if your still having probs, uninstall and you most likely have a corrupt registry key if you installed incorrectly then install this link and see if you still have same prob
Nanofurry
Post by Nanofurry »
Sexacutioner wrote:if you dl from the link tricky gave you then you probably installed it wrong, ive had to help 5 others with same problem with that link
ah thanks. ill let my networktech no that.. lol we both play to gether and we have been trying to get it to work for 2 weeks.
are both of you on lobby client too ?
Nanofurry
Post by Nanofurry »
[-Ts-] Tricky wrote:are both of you on lobby client too ?
me my boy friend and the network guy yes
Evydder
Lobby Username: Evydder
Post by Evydder »
Hey, I am Nanos Network Guy,
None of my duo core cpus pcs (i have a intell core 2 duo and a AMD Athlon(tm) II P360 Dual-Core), Dont have the issue only the quad cores do.
With the Quad core one of the 4 cpus get max out but on my dual core (i am hosting) none of mine is maxed out.
My Net is 30 mbs download and 10 mbs upload.
Laptop specs
500gb hdd
AMD Athlon(tm) II P360 Dual-Core 2.3 ghz
8gb of DRR3
Oldspice
Lobby Username: Oldspice Guy
Post by Oldspice »
You can't make ee use more than 1 thread because multithreading isn't programmed into it (since the idea of multiple cpu's didn't occur to people over a decade ago). I've no idea why it's "maxing" your cpu, it's not that intensive.
President Obama
Lobby Username: President Obama
Post by President Obama »
What are you doing exactly when it maxes out?
Try closing all non essential processes also. EE only uses 1 core, like mentioned before it only uses 1 thread. Quad/Dual core shouldn't affect it at all. Chances are its another process interfering or something you're doing in ee.
run in win 7, vista or xp compatability mode
try lowering your screen resolution to 1440 x 900 or lower on your monitor then in your game to see if thats something giving you issues
in game options change to a dif video adaptor and activate it
scan for bad registry keys to make sure youve gotten rid of all of them, ccleaner works pretty good and its free
Try overclocking your CPU.
Users browsing this forum: Bing [Bot] and 8 guests
