EE Patch instalation [need help]
snoeppot
Lobby Username: snoeppot
Post by snoeppot »
Hello,
I have a problem installing the multiplayer patch.
I can install EE without a problem.
But then when i try to install the patch (Downloaded from www.neoee.net) it says error.
Nothing else but just error. It worked before but now i reinstalled the game and it doesnt working anymore.
There is no name for the error, it just says error.
Please help me,
Snoeppot
Re: EE Patch instalation [need help]
Stuur eens een bericht naar jodocus of Realforce, zij zijn de makers van neo-ee en kunnen je verder op weg helpen.
RealForce
NeoEE Developer
Lobby Username: RealForce
Post by RealForce »
sorry for late response..
Try this setup_we prepared it special for ur case
http://www.neoee.net/NeoEEsp.msi
Good luck mate
Regards
snoeppot
Post by snoeppot »
Okay i will try it tomorrow, im on my phone now going to sleep, i will update you if it works or not :)
snoeppot
Post by snoeppot »
hello, it still doesnt work realforce, i have windows 7 x86.
It still gives the same error.
snoeppot
Post by snoeppot »
It first says Error, and then delete's alot of files in the sierra --> "empire earth" folder.
Hm what happened? I have it installed manually for you and now it is broken again? In case you are still trying: I am reminding RealForce on your case, we won't give up.
snoeppot
Post by snoeppot »
well Jodocus, you installed in manually, worked greatly, but after a while every time i joined a multiplayer game i timed out, i've had that before so i reinstalled the game (worked before so) but then the patch doesnt work. :(
Greetz,
snoeppot
Post by snoeppot »
bumpp -----
please help
snoeppot
Post by snoeppot »
fixed by realforce :)
thankss
