Can't log into EEC
Xfire: p51p51
Lobby Username: «•FRMB•»P-51
Can't log into EEC
Post by P-51 »
In the top left corner of my game it says that I am running v2.00.2539
When I try to create a user name and log in it says that I am running an outdated version and need to patch the game. I click "OK" and that exits the game and sends me to windows, where I get this message.
After clicking "Exit" and relaunching the game I get the same shit and I am stuck in some weird loop. I either need to install a patch manually or find a way to remove a false error message. Can someone help me with this?
Xfire: p51p51
Re: Can't log into EEC
Post by P-51 »
Bump Bump Bump Bump
Ehm open zzWONVersion (the cfg file inside EE folder)
Should say:
Version: 2.0.0.4
If not, maybe try manually changing to that. I got no clue if this will help or make it worse though.
Did you try full reinstall?
uninstall -> ccleaner -> remove bugged registry shit -> install EE 1.0 -> run patches -> go.
You should be alright if you just try to download the NeoEE patch again and install/repair. Manually changing zzWONVersion.cfg will allow you to login again, but your EE version won't match if you got an older version of the NeoEE patch.
Xfire: p51p51
Post by P-51 »
I tried uninstalling and got this error. I got it for both EEC and AoC. Does anyone know what this means?
i cant login either as it says my cd key is invalid... any ideas?
@P-51
No clue:S
@Slipknot
Does your version say v2.00.2949?
If so open WONlobby.cfg in EE folder and change CDKeyCheck to false.
CDKeyCheck: false // was false
I had this problem too, and this fixed it.
cheers
Xfire: p51p51
Post by P-51 »
Jodocus wrote:You should be alright if you just try to download the NeoEE patch again and install/repair. Manually changing zzWONVersion.cfg will allow you to login again, but your EE version won't match if you got an older version of the NeoEE patch.
Hey that worked. Thanks!
Users browsing this forum: Bing [Bot] and 22 guests
