Cannot Load Saved Games
bfunk99
- Lobby Username: bfunk99
Is there a fix or a work around for not able to load saved games for AOC? Everything else is good, but I noticed when I try to load saved games using multiplayer NeoEE, it seems not to load. Any thoughts would be appreciated, thanks!
Re: Cannot Load Saved Games
port foward, then you will be able
at target IP adress, it's the local IP adress that you see in-game, in-lobby at the Options tab, at Local IP.
Once you port foward, you will be able to load games.
Just as a notice, you can only port foward if you are using IPV4 from your ISP.On IPV6, this is no longer available.
bfunk99
Got it thanks again!Bogdan_xD wrote:port foward, then you will be able
bfunk99
Thanks Bogdan_xD, that worked with forwarding the ports on my router!Bogdan_xD wrote:port foward, then you will be able
