How to setup scen for multiplayer
SHETMAN
Lobby Username: SHETMAN
Post by SHETMAN »
There is a probably a really obvious answer to this but I have no clue how to load a already made scenario online for me and my buds to play on.
Black Star
Lobby Username: Die Gurke
Re: How to setup scen for multiplayer
Post by Black Star »
Are you talking a bout a Scenario you made yourself or one that you downloaded from somewhere ( like this Forum)?
If you downloaded it, it should be an .ees file, which means it is a saved game. So you just have to put it in the "Saved Games" Folder of your EE. You then can load it as a normal saved game, if you make sure you guys use the correct names ofc. Easiest way to do this is via Direct Connect Option in Other Mulitplayer.
If you're talking about your own created scenario, please read the following article
viewtopic.php?f=94&t=2313
SHETMAN
Post by SHETMAN »
prefect thanks
