Crack v2.0
AraGoRN
Crack v2.0
Post by AraGoRN »
Hi anyone can help me, plz
Have problem with EE no cd crack v2.0 it dont work
Re: Crack v2.0
Ok, this seems like a case of someone not reading the guidelines for requesting support...
SO, you need to tell us the following:
1) Explain EXACTLY what you did to apply the no cd crack, step by step.
2) Expain what you mean by "it dont work". Seriously, this could be anything from "when I try to run ee it asks for the CD" to "when I try to run ee absolutely NOTHING at all happens" to "when I try to run EE my entire computer crashes" or whatever.
You see, the problem is caused by something. Unless you give us specific information to help us pinpoint what the problem is, we can't help you, and, for everyone else reading please actually read the guidelines before posting in the future, because we really DO get tired of explaining this exact same shit over and over and over again.
AraGoRN
Re: Crack v2.0
Post by AraGoRN »
Ok srry I forgot read guidelines. :mrgreen:
1)EE install first version, then update to v1.04, then to v2.0 and finally i paste crack in EE folder
2)when I try to run ee it asks for the CD
thanks for help :D
Re: Crack v2.0
When you paste it to your Empire Earth folder, does it open a dialog box asking you if you want to overwrite/replace the existing .exe file? If so, are you hitting yes? If you're not hitting yes to that, try it and it should work. If you are hitting yes to this, try a different no-cd crack, or just log on to the lobby hit the patch button and tell it to crack you.
If if doesn't open that at all, do the following:
1) Ensure you actually have the right Empire Earth folder--make sure you're not copying it the AoC folder or something like that.
2) If you're sure you have the right folder, delete the Empire Earth.exe file that's already there and THEN copy the new Empire Earth.exe file to the folder.
Re: Crack v2.0
you can also no longer use your quick launch from your start menu or any desktop items you may have placed, you will have to pin your new exe to your menu or create new shortcuts on desktop
AraGoRN
Re: Crack v2.0
Post by AraGoRN »
Yeah it work now :D :D :D
I create new shortcuts on desktop and now is ok
Thx for support guys :P I am very grateful
dasteve
Lobby Username: colonel steveson
Re: Crack v2.0
Post by dasteve »
*PSSSSTTTT* So uhmm... where did you get this cracked version? *cough* can i get a link? *cough* *cough*... Man this cough is getting bad. *clears throat*. :D
Re: Crack v2.0
click patch in the lobby and where it says ee and aoc no cd
