Disable Prophets?
CCode
- Lobby Username: notyet
Disable Prophets?
Hi there,
i love to play EE against the Computer. But the problem is that i dont want to play against reli (prophets and priests). In my oppinion they are destroying the harmonic gameplay.
Is there any way to stop the Computerplayer from using Prophets or priests? Of course i do not want to use them too.
Please help me.
Thanks for your ideas
My best Regards
CCode
Please help me.
My best Regards
CCode
Texas Ranger
- Lobby Username: Texas Ranger
Re: Disable Prophets?
1. Build Temple
2. Build University
3. Profit
2. Build University
3. Profit
Temples prevent enemy Prophets from being used within their range. Universities prevent enemy Priests from converting within their range. Build them around your base.Texas Ranger wrote:1. Build Temple
2. Build University
3. Profit
Or alternatively you could open up the scenario editor, generate a random map with you and a computer, remove religion from the tech tree, and make use of the "test" feature (although I don't think it will say you've won when you've killed all his units and buildings, so you could just quit when you do).
- Sexacutioner
yeah it will say you won but it wont give you stats but if your just playin the comp for the hell of it then not sure if you worry about stats
KillerTomato
- Lobby Username: KillerTomato
If you go on the Empire Earth section of Heavengames.com you can find a mod I made that will take care of the Prophet. I made it a long time ago though, I don't remember if I removed it from the tech tree or just removed all of it's 'power' or 'mana' whatever it's called. Either way it removes the incredibly annoying threat of plague and volcanoes and all that nasty stuff! However it will change your game version, so I recommend installing it in a separate install of EE if you play online.
Ex-Empire Creations, Ex-Scenario Designer, Ex-Modder.
- DJay
- Trichome Indica
Hey
I also used to have a thing against Prophets and Religion in general. Thought it SUCKED ;
so I posted my opinion and was enlightened to learn from other users the potential, and fun that could be had.
Have a look for yourself. viewtopic.php?f=10&t=253
Maybe it will change your mind too.......
- Noob @ Everything
Firestorms and earthquakes are effective in all ages.OwnageDJ wrote:There is a way!!!
Play mod and upwards only!!
KillerTomato
nevermind about me useless prophet mod... it seems it's been erased from EEH for some odd reason.
- DJay
