Can't play multiplayer
RogueStove
- Lobby Username: RogueStove
I keep getting the error no CD-Key when trying direct access with my two friends.
Bogdan_xD
Re: Can't play multiplayer
why not use the Lobby then?
or can't you connect to that either?
Try to run the installer and hit "Repair CDKey". Good luck, Jodocus.
RogueStove
LAN works but im trying to play with another friend from far away. Every time i try to install or repair CD keys it tells me 'CD KEYs could not be installed due to command line failure.'
RogueStove
Ok I've figured it out. Thanks all who tried to help.
supercooler88
- Lobby Username: supercooler88
HOw exactly did you figure this out. Can you please explain?
Thanks,
Thanks,
Bogdan_xD
Install the NeoEE patch with the antivirus dissabled . Antivirus is stopping the installment of the CD-KEYS.If you have it dissabled, when you install the patch, it should say at the end "CD-KEYS succsesfully installed" , if it doesn't it's because of your antivirus stoping it.
Just dissable the antivirus, install the patch and make sure you get that message, then you can re-enable your antivirus.
