My Router is Asus RT-AC87U and Portal.
I only tried the former one, my family refuse to let me change it (lame excuse I know.)
I had tried to set up portfoward and the normal NHT(which said 90% will work,I guess I'm the 10%), neither works.
I can't connect locally with my family and friends too.
So the last resort I can think of, is asking you to add the router in to one of your supporting list.
Please help add router.
LackZer
- Lobby Username: LackZer
Re: Please help add router.
We don't have a supporting list for routers. The way to host online at NeoEE is by portforwarding. This part is tricky, you need to make sure 33334-33336 UDP/TCP to the correct local IP address.
One way to figure out your local IP is to check when you are logged in NoeEE in the Options tab. Also if you have red arrows like in the image above that means that you have NOT portforwarded correctly.
LackZer
Ah I see, I do get the red arrorr at the internet part.Arntzen wrote: ↑Sun May 01, 2022 5:14 amWe don't have a supporting list for routers. The way to host online at NeoEE is by portforwarding. This part is tricky, you need to make sure 33334-33336 UDP/TCP to the correct local IP address.
My asus router can't set two seperate local IP for the same portfoward number, because my PC and my brother gets different local IP while connected to the same router thorugh wifi. I guess the quickest way is to change router
Only the host needs to have port forwarded. No need to buy new router
Users browsing this forum: No registered users and 38 guests
