Topic about download "Eec CivPackage Fixed"
Moderator: taco
Topic about download "[Outdated]Eec CivPackage Fixed"
Description:
Here is a small civpackages that will give u the most needed civs for p2n/p2n island/mid sh/grenwar/mod sh
Also Lightnessking found an error in the other civpackages. One of the Mod civs had Cav Sword Attack insted of Citizens Hp. This is now fixed.
File: Kazter\'s EEc-Civs.rar
Re: Topic about download
Here is photo's of how my civ looks like.
This is an Club mass civ, also called the BTD civ in P2N. It has everything you would need for a massciv rush except building btd. I find it unnecessary because I will use all my 20citz on the 2 barracks in start, and also 12 citizens on towers right after.
This is my verson of a Spear mass civ. I would only recomend useing this in a 3v3 situation since it doesnt have Popcap. What it also doesnt have is building Cost Reduction, something I dont think you will need since you can allready afford six houses and 3 towers. Also you only need 15 more stone for a temple.
Spearciv with weaker spear that doesnt have HP but massive boom. I really like this civ and have had alot of success with it.
This is the Pocket civ I'm useing when I play P2N Island games. It doesnt have building CR, this makes you abit slower but in exchange you have cost reduction on bombers something that will really help you later in the game.
This is my Wing civ for P2N Island games. The only thing you might be missing is fire rate on seige, something I dont find necessary because against a good enemie you will have to micro then back and forward anyway.
This civilization is the 1v1 verson of Cav that I have had most success with.
3Cav Arch.jpg (34.2 KiB) Viewed 45239 times
The best Cav civ for teamgames in my opinion.
Standard Civ for longswords. More info here: viewtopic.php?f=59&t=868
The one and only grenwar civilization. More info here: viewtopic.php?f=59&t=892
Ras's Air civ for Mod sh. You start out massing fb/fighters and end up makeing pretty much everything. I really like this because you are able to help out your wing with strong ground army, and you also have the choice of supriseing with some bombers with good speed and hp.
This civ is also made by Ras. It's a really strong tank civ where you start out 12iron rest wood and end up haveing 2 tank factories after first drop of wood. This civ even beat most weak AT civs. It also has strong seige powers that helps alot late game, and can be used for flaks. This makes the civ pretty good in 1v1's as well as teamgames.
This civilization to me looked awefull when I saw the civ only. But when I learned how to use it, it turned into my favourite civ by FAR in mod sh. You start out making a dog, tc gold and make two towers to cover 1 gold and 1 iron. Then basically counter your enemie with either tank or AT's. You tower one iron mine in start to secure it incase your enemie is inf-rushing you. Your goal in this civ is to get to 3 farms and from here just take over all the mines u can get to. This civ was made by Ras.
