Hosting
Darkalliances
Lobby Username: Darkalliances
Re: Hosting
Post by Darkalliances »
Well thanks for the advice, and being on the EE community in general. But I am on the same computer where i was able to host at a different location. i did notice some of the IP's were odd. like the first one would be 1093:08:EFZw:095T:0056
Thats just a random example but it looks like that, but below it there is a normal IP that i use instead
Re: Hosting
The top one you're talking about is IPv6. Just ignore it and pick the other one which is IPv4.
Darkalliances
Re: Hosting
well thats what i have been doing, i thought maybe it was a sign that this problem couldnt be solved
Darkalliances
Re: Hosting
Any help would be great. I did the whole routine at my old appartment but here i cant get myself hosting
Re: Hosting
Darkalliances
Re: Hosting
Darkalliances wrote:Well i did the whole port forward thing at my appartmet a couple years ago, worked fine. But now here i do the same thing and it wont let me host, i double check and triple check and i know im doing it the right way so i know there is some reason i cant host?
Darkalliances wrote:Well thanks for the advice, and being on the EE community in general. But I am on the same computer where i was able to host at a different location. i did notice some of the IP's were odd. like the first one would be 1093:08:EFZw:095T:0056
Ghost, no offense, but if you read my posts im trying to find the other problem, because just forwarding my ports and all that isn't working. Do you know about any other problems or reasons why i would not be able to, aside from the obvious, forward ports/firewall/trying to do it in LAN, instead of DC.
Maybe there are certain routers that just wont let you host no matter what?
eeralf_
Lobby Username: eeralf
Re: Hosting
Post by eeralf_ »
hello Darky welcome back my friend, but sry, i use the same comp on 2001, and all work, so its a setting problem of u, ur router/firewall / ports or any, but not a software problem from lobby and so
pls check all, and u see all works fine
i know its not easy for someone, buts the life, and comps are stupid Insects.;)
Proooost darky
Darkalliances
Re: Hosting
eeralf_ wrote:hello Darky welcome back my friend, but sry, i use the same comp on 2001, and all work, so its a setting problem of u, ur router/firewall / ports or any, but not a software problem from lobby and so
Proooost darky
Prroooost to you alt friend. But even gott in himmel cant help me at the moment. I am using the same computer that i could host on 2 years ago, but now i have a different router and ISP. Even forwarding ports wont work. I might have to move in with you in Germany just so i can host ^_^
Meine Deutchse icht nicht gut
Re: Hosting
Sorry, last post I didn't realize this was the second page.
Try plugging your computer straight into the modem... if it works then it's your router. If not, you may have a modem or ISP firewall. If it's a modem/router combo then see if your ISP will give you something else. Otherwise you may be screwed and have to bitch at your ISP.
Darkalliances
Re: Hosting
Ghost wrote:Sorry, last post I didn't realize this was the second page.
Thank you so much man, that was it. i plugged directly into my modem but it wouldnt work, but there was an option to forward ports in my modem config, 33334-3336, tcp and udp and now i can host.
Thanks for the help
Users browsing this forum: No registered users and 43 guests
