Crash mission campaign
TheNefarem
Post by TheNefarem »
Hi, I have another problem. Now when I run any mission with the basic version of Empire Earth, immediately turn off my game.
Re: Crash mission campaign
Post by [-Ts-] Tricky »
windows 7 ? or 8 or 8.1 ?
TheNefarem
Windows 7, Windows 8 on the second, and both crash
RealForce
NeoEE Developer
Lobby Username: RealForce
Post by RealForce »
Well,ur problem seems related to ur antivirus
If u have any anti virus just disable it temporarily and see if campaign,single and,multi work
regards
RealForce
also is your ee a cd or download if download where did you download it ? utorrent,save ee ?
TheNefarem
@ [-Ts-] Tricky, My CD, if I might add that it is important in the Polish language version, because I have heard somewhere that it is important.
@RealForce, I disabled the anti-virus but it did not give.
go to www.neoee.net download the patch for your cd it will have polish language
and then see if works with it
TheNefarem
I downloaded and installed the patch for the Polish version and nothing.
In addon, normally I run missions.
viewtopic.php?f=10&t=4889
download patch after installed from www.neoee.net
try this ee and aoc download and see if you still have same problems after
TheNefarem
Yeah! Work, thanks ;3
Brickington
Post by Brickington »
I'm having this problem, and nothing's showing up that would have me believe it's an issue related to my AV. I am using Avast, if that means anything. Running Windows 7.
It only seems to come up at odd times. After I tested the whole game to see if there would be an issue with random map, it worked fine. The next thing I know, the campaigns are working fine.
Why could that be?
ill get someone to reply back to you
