cdkey problem
-NeW-
cdkey problem
Post by -NeW- »
i installed the new neoEEpatch, the problem is say my key isnt valid
pd: i havent "HostPingRIP.txt"
pd2: in "WONLobby" i write "false"
Re: cdkey problem
Don't write false there. After updating, there must be written "true". HostPingRIP.txt is gone in the new patch. Re-run the installer and hit Repair CDKey. Make sure no antivirus program is interfering. Also make sure that the installer can use the internet. Do you get any error? If yes, which one?
-NeW-
Re: cdkey problem
Post by -NeW- »
i continue with problem i reinstall neopatch... invalid key :(
RealForce
NeoEE Developer
Lobby Username: RealForce
Re: cdkey problem
Post by RealForce »
-NeW- wrote:i continue with problem i reinstall neopatch... invalid key :(
whenever u hit repair cd key?
what error u r getting during the repair wizard?
Re: cdkey problem
I repeat: what error did you get from the installer? Have followed all my instructions? Can you give me a screenshot of the installer error?
-NeW-
Re: cdkey problem
Post by -NeW- »
WONlobby==>
Language: ES
ProductName: EmpireEarth
ProductDirectory: /EmpireEarth
DirServer: titan.neoee.net:15106, neoee.4dq.com:15106
ResourceDirectory: Data/WONLobby Resources
LanBroadcastPort: 8585
EEFileTransferPort: 33335 // new
LobbyPort: 33336 // new
UseLocalIP: false // was true
NoPingInProgress: true
CDKeyCheck: true // was false
CRCCheck: false
CheckForInternet: true
Public: false
AllowDuplicateNames: false
AppendNumberToDefaultLanName: true // was false
AllowJoinGameWithoutPing: true // new
// Include version file
IncludeFile: "zzWONVersion.cfg"
-NeW-
Re: cdkey problem
Post by -NeW- »
the message say when i start EE in multiplayer is==>
"cd key invalid, reinstall game and write a valid key"
Re: cdkey problem
Okay. What happens when you go to Installer and hit repair CDKey?
RealForce
NeoEE Developer
Re: cdkey problem
Post by RealForce »
-NeW- wrote:the message say when i start EE in multiplayer is==>
We understand
But whenever you click repairer cd key Wizard
what it says?
or it just says your cd keys are successfully installed?
or there is an error code? (could you tell us what error code you are getting)?
-NeW-
Re: cdkey problem
Post by -NeW- »
i repair cd key in neoEEpatch 1000 times and problema continue
Re: cdkey problem
-NeW- wrote:i repair cd key in neoEEpatch 1000 times and problema continue
Sorry, I have to repeat myself, but you didn't answer our questions. What does the installer say when you clicked Repair CDKey? Will it show an error? Will it say that it could successfully install? In order for us to help you, you must be more elaborate on your problem.
Re: cdkey problem
If anybody has similar problems, please write to the guestbook, the forums or e-mail (support@neoee.net).
Binny
Lobby Username: Binny Baffeedo
Re: cdkey problem
Post by Binny »
repair CD key does absolutely nothing
TAZ_XK
Lobby Username: TAZ_XK
Re: cdkey problem
Post by TAZ_XK »
same problem, and repair cd key cannot contact licensing servers
where is store the cd key ??
Re: cdkey problem
Hi!
If you cannot contact licensing servers, some firewall or antivirus might be blocking the connection.
