also I don't know if its about the ports because they are already open as much as I know.
would really appreciate any help
This works.lightnessking. wrote:You can try sending him the datafile via skype or any other data transfer service. Then he should put it in the saved games folder and you should be good to go.
Arntzen wrote:This works.lightnessking. wrote:You can try sending him the datafile via skype or any other data transfer service. Then he should put it in the saved games folder and you should be good to go.
Also if you want to be able to load save games in multiplayer without the hassle of having to send the file etc.. You could portforward (33334-33336 udp/tcp) and it is automatic. Only the host needs to have port forwarded.
But thank you for your input.HellToad wrote: also I don't know if its about the ports because they are already open as much as I know.
Oh his comment was not superfluous. Apparently, the port forwarding of the TO did not work, either because he hadnt used the right ports or one of thousands of other reasons.lightnessking. wrote:But thank you for your input.HellToad wrote: also I don't know if its about the ports because they are already open as much as I know.![]()
We both have the same file, it is an autosave one, will try that though tylightnessking. wrote:You can try sending him the datafile via skype or any other data transfer service. Then he should put it in the saved games folder and you should be good to go.
