Cd Key could not installed due to comand line failure
KellogZ
Post by KellogZ »
Hi folks, trying to reinstall EE with NEOEE right now and I am getting the error message from the title. Any known solutions?
KellogZ
Re: Cd Key could not installed due to comand line failure
Post by KellogZ »
If this helps:
KellogZ
Post by KellogZ »
What somehow worked was the complete NEOEE install from the website... but it is still version 2.0.0.4 and I am not able to connect with that or update it. Any complete install with the current version out there?
Post by Locodoco »
did you try disabling Antivirus while doing this?
_[eC]_Arntzen_: :)
KellogZ
Post by KellogZ »
Yep, that was the first problem, but obviously that has been talked about a lot. I also suspected a Firewall issue because I read the CD Keys are downloaded, but even turning off my firewall completely didn't solve the problem. It also looks like the Install afterwards is running normal and at the end I get the message "succesfully completed" but nothing about the files (size etc.) in the EE folder has changed. What would really help me (I think) is a full NeoEE install like the one available on the website but in 2.0.0.5 instead of 2.0.0.4. If someone feels like zipping that up or something...
D55
Lobby Username: D55
Post by D55 »
I have never seen this problem before, you might need to wait for a response from Jodacus before finding the solution.
Have you chosen automatic or manual mode? Try either. Are you also trying to install AOC? If so, try without first.
Is the error message the same when you re-run the installer with "Repair CDkey" option?
CaveMan
Lobby Username: CaveMan
Post by CaveMan »
I need help because I have the same problem. I tried to reinstall neo ee to repair cd key but it won't let me click on it.
The version is updated and I have the lobby login page but I cannot sign in due to invalid cd key.
CaveMan
Post by CaveMan »
Language: EN
ProductName: EmpireEarth
ProductDirectory: /EmpireEarth
DirServer: titan.neoee.net:15106, neoee.4dq.com:15106
ResourceDirectory: Data/WONLobby Resources
LanBroadcastPort: 8585
EEFileTransferPort: 33335 // new
LobbyPort: 33336 // new
UseLocalIP: false // was true
NoPingInProgress: true
CDKeyCheck: true // was false
CRCCheck: false
CheckForInternet: true
Public: false
AllowDuplicateNames: false
AppendNumberToDefaultLanName: true // was false
AllowJoinGameWithoutPing: true // new
// Include version file
IncludeFile: "zzWONVersion.cfg"
